Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
Thread Tools Display Modes
  #1
Old 24-09-17, 07:28 PM
Cigarjohn's Avatar
Cigarjohn Cigarjohn is offline
Member
Question M.2 Bandwith usages!
I'm going to be purchasing an Asus z270 WS mobo and when using the M.2 in the M.2_2 slot it says, "The M.2_2 socket shares bandwidth with U.2_2 connector and SATA6G_1 port".
I'll be using the Samsung 960 EVO 250mb version as an OS drive that will be partitioned. SATA Port 1 will be used for my Blu-Ray drive. Will performance be degraded for this M.2 since it shares bandwidth with SATA Port 1?
  #2
Old 24-09-17, 08:01 PM
WYP's Avatar
WYP WYP is offline
News Guru
I assume you mean this motherboard?
https://www.asus.com/uk/Motherboards...pecifications/
In the case of the M.2_2 port, the SATA port will only be disabled when you use an M.2 drive that runs on SATA mode. So a proper NVMe drive will not disable the SATA port. When using a NVMe/PCIe device only the U.2 port will be disabled.
In your use case, this should not be a problem, as the M.2 slot will only use the SATA bandwidth if it is using a drive in SATA mode, which it won't do with the Samsung 960 Evo.
__________________
_______________________________
Twitter - @WYP_PC
  #3
Old 24-09-17, 10:20 PM
Cigarjohn's Avatar
Member
Thank you for your quick reply. Greatly appreciated!
P.S. are you familar with installing an OS on a M.2 drive?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
