Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
Thread Tools Display Modes
  #1
Old 12-05-17, 09:50 AM
coccosoids coccosoids is offline
Newbie
Drive configuration OS / Cache
What is recommended: to have: a fast m.2 drive with enough capacity for paging and caching (think of an after effects cache folder and the OS page file), or option 2 - to have a dedicated SSD (on a sata port) for paging and cache coupled with a sata ssd for OS?
Any other thoughts?
Thanks.
  #2
Old 12-05-17, 11:46 AM
Avet's Avatar
Avet Avet is offline
OC3D Elite
Just run the fast m.2 as OS drive. Disable the page file. Or put it on 400 mb for some apps that go wonky without it. There is a guide on formus how to setup your OS for ssd. Do that and enjoy.
  #3
Old 12-05-17, 12:01 PM
Newbie
Problem is I only have 32gb or RAM and I frequently top it if I run Photoshop and a 3d app or After Effects... speaking of which - caches for these apps often top 20, 30GB each - hence my predicament.
  #4
Old 12-05-17, 12:13 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
Yeeah you don't need a pagefile, stick a 1GB one somewhere on a fast drive and forget about it. Some games 'require' them for swap-space but you should almost completely ignore the windows recommendations for it.
Set your Adobe scratch discs manually to whatever the fastest drive you have is that doesn't have the OS on it. They work best if not using the OS drive and love RAID arrays too, usually for that kind of work you just dedicate a fast drive to NOTHING but scratch IOPs then leave it alone.
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
