Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
Thread Tools Display Modes
  #1
Old 18-04-17, 09:56 AM
Cipher . Cipher . is offline
Newbie
Samsung 960 Evo 500 GB or 2x 960 Evo 250 GB in Raid 0?
Hi all, I am going to upgrade to a 960 Evo for my boot disk and was wondering which would benefit me in terms of speed having a single Samsung 960 Evo 500 GB or having two 250 GB Evos in raid 0? there is only like a £12 difference between the two options so it basically comes down to performance.
  #2
Old 18-04-17, 10:24 AM
tinytomlogan's Avatar
The Guvnor
What board? Raid can be a mare to set up on M.2 and can be a bit hit and miss tbh.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 18-04-17, 10:30 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Plus, wouldn't he really not notice this speed in real life? Just mostly might see the difference in digits, ie if he does a transfer test?. If you get what I mean here?...
If you would ask me, I would always go with the same as I do with GPUs... I always get the highest end, single card that I can afford. Never more than that, ie I'd personally go for the single 500GB one. Less headaches that can happen etc.
  #4
Old 18-04-17, 10:34 AM
Newbie
Thanks for the quick replies TTL and Chrazey, I have a Asus Maximus IX formula, Thanks for the great review on it by the way
  #5
Old 18-04-17, 12:56 PM
jimma47's Avatar
jimma47 jimma47 is offline
OC3D Elite
I'd go one large one and save the trouble. Like it's been mentioned the difference in speeds will be more synthetic than actually noticeable. Plus it's half the things that can go wrong. If one 250GB drive dies you lose the whole array anyways so with two drives you have double the risk (although the risk is still very low)
__________________
Rig Gallery - Krusty III
  #6
Old 18-04-17, 12:58 PM
Dawelio's Avatar
OC3D Elite
But the risk is still there and it's significantly higher than with just a single drive, ain't it?
  #7
Old 18-04-17, 01:00 PM
jimma47's Avatar
OC3D Elite
That's what I just said
Edit - ssd catastrophic drive failures are still pretty rare but double the 1/1000000 chance is still double. (I just made that figure up btw I am too lazy to google)
__________________
  #8
Old 18-04-17, 01:26 PM
The Guvnor
Yeah Im with a single large drive too tbh.
__________________
  #9
Old 18-04-17, 01:33 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
As has been said already 1 large drive is the way to go
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #10
Old 18-04-17, 02:13 PM
Newbie
Thanks all, knew I could rely on you guys for the right advice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
