Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #1
Old 02-06-16, 07:38 PM
hunter678 hunter678 is offline
Newbie
s340 Cable management sheath replacement
im upgrading my mobo and wan to change the colour of my build from a blue and black theme to a black and white. Anyone know if you can buy replacement cable management sheaths as i would like to try get my hands on a white one.
if they're not available as spares can anyone suggest what sort of paint would be good to use to respray it ?
thanks for your help
  #2
Old 29-08-16, 08:28 AM
lebel22 lebel22 is offline
Member
The sheath is held in by screws so why not just take it out and spray it a colour of your choice, I sprayed mine white to complement my Asus Pro etc.
Edit: Sorry, I didn't read properly. I used Halford's mat white spray, no sanding etc, anything would work as long as sticks I suppose .
  #3
Old 22-09-16, 12:36 AM
NZXT_Harry NZXT_Harry is offline
Newbie
Hello! We do have them available as spares if you want to buy it from us. Just send in a ticket at Support.nzxt.com
Tags
modding, nzxt s340, replacement
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
