Thread Tools Display Modes
  #11
Old 04-04-16, 04:47 PM
Thelosouvlakia's Avatar
Thelosouvlakia Thelosouvlakia is offline
Classy-Fried-Chicken
This is going to be awesome. I'm wondering how quiet it is going to end up being.
__________________
Theory is when you have the "know how" but nothing works.
Practice is when everything works but no one knows why.
In our lab, theory and practice are combined: Nothing works and no one knows why
  #12
Old 04-04-16, 10:24 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
That PSU looks awfully alot like some of the PSUs that are used in XPC shuttle PCs. They do tend to die after a few years. Where did you get that psu from?
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #13
Old 14-04-16, 03:29 PM
JamesGoodfella JamesGoodfella is offline
Newbie
Yup! It's a shuttle PSU, it was as eBay jobbie about a year ago. Got it cheap so if it does die i'll buy a new one.. saying that though, I've not even tested any of the hardware I've bought!
__________________
  #14
Old 21-05-16, 08:04 PM
Newbie
Hi all,
Another friend has lent me their Dremel so the NES project is back on!
Cut out the hole for the PSU on the right side.
All the edges are rough and need finishing but the bulk of the cutting has been completed.
With the PSU in, it's a ridiciuosdly snug fit.. top and bottom of the NES are touching the PSU!
Now that most of it has been cut out, I will make a IO shield holder which will be wide enough for the PSU to bolt on using the 4 screws And I will see if I can bend it so it can act like a motherboard tray too.. if you guys follow. I'll jump on Google Sketchup later tonight and draw a extremely rough model. (Would use Solidworks but I'm not going down the super precise route like I would in work as I'm doing this all to eye)
As for the huge cut out I've made in the floor of the NES, I may fibre glass it as it's so flimsy it'll snap in half and I rather not have to go out and find a faulty NES again.
__________________
  #15
Old 21-05-16, 08:14 PM
WYP's Avatar
WYP WYP is offline
News Guru
nice, I look forward to seeing more. I love these case mod builds.
__________________
_______________________________
Twitter - @WYP_PC
  #16
Old 21-05-16, 09:03 PM
Newbie
CAD model done, nothing special just to aid with explaining my plans.
Ideally I'd like to be able to just push the IO shield into the back of the NES
__________________
  #17
Old 22-05-16, 09:06 PM
Newbie
I'm going to try to fit in a SSD somewhere inside the NES but to keep the whole build themed to my NES, i'm going to convert a NES cartridge into a hard drive.
http://www.instructables.com/id/How-...tern/?ALLSTEPS
Also having second thoughts on whether that corsair H5SF will actually fit, even if I modify the mounts to lower it. So I may go with the Noctua NH-L12, I've always had a soft spot for Noctua's products.. Used to be able to overclock my 3570k to 4.8Ghz and it will kept it cool enough to use! The NH-L12 is 66mm without the 120mm fan on top which will be perfect, still enough to cool my APU.
As I don't really plan to make the inside super tidy like previous builds, I'll just use some self amalgamating tape and tidy up all the psu wires.
Ordered some mesh for all the holes and a A3 sheet of clear acrylic, taking notes form ungreedy's NES 3.0 build. He seems to have it all figured out well and it definitely shows
__________________
  #18
Old 22-05-16, 09:21 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
How are you going to deal with heat and airflow with such a small unit?
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #19
Old 22-05-16, 09:28 PM
Newbie
Probably end up cutting a vent in the right side(if you look from the front) of the top half of the case. There already is a vent in the to which runs the length of the case anyway. I may cut open the top vent a little more then just put some super fine mesh to reduce the amount of dust that gets into the case.
__________________
  #20
Old 24-05-16, 06:08 PM
Newbie
So when I was looking at the H5SF specs today, I checked the total height which was 84mm I was sure I'd simply be able to cut the bracket to reduce the height to something that would fit inside the chassis.
I was wrong. I checked to see how flexiable the hoses are to actually allow me to squish the pump/block right up to the rad but I can't do it without putting serious strain on the hoses and even then.. I can't get the block to line up with the brackets. To make things worse I miscalucated the depth - thought it would be a snug fit in the nes in this case it's just a few mil oversize. Seriously gutted about this.
Sorry for potato, using a chinese phone because it has a 6,000mAh Battery and the camera is horrendous. Will use my slr for final photos don't you guys worry.
But yeah, it's far too big and if I did make it fit the rad would have to be sticking out (not happening )
Anyway, I'll be going with the Noctua NH-L12 instead.
Also fitted the APU and RAM tonight, just because I've got nothing to do until parts arrive.
PS selling Corsair H5SF cooler
__________________
Tags
modding, nes pc
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
