Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #41
Old 27-04-16, 07:23 PM
tinytomlogan's Avatar
The Guvnor
The AX860i hasnt got digital control to the same level that the AX1500i has.
Im sure they have some kind of digital to analogue converter built in to get the link stuff working.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #42
Old 27-04-16, 07:32 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Very odd indeed, The only thing I can think of then is the Asus bios doing something funky like throwing out false positives like Corsair say on their FAQ, I'll keep you updated anyhow.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
