Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 17-03-16, 07:54 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
AX860i Going Faulty
The last few days my system has been randomly losing power and shutting down.
Upon reboot the bios screen says there was a surge and upon closer inspection the fan isn't starting to spin at all unless I set the RPM in Corsair Link, Even the "Test Fan" button has stopped working.
Is there any way to do an RMA that sends out a PSU and collects the faulty 1 at the same time ?
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #2
Old 17-03-16, 08:08 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Sorry to hear that man. You can request for an Express RMA when you submit an RMA request. I can assist you once your RMA is already approved.
So when you did the self test, did you unplug everything from the PSU?
  #3
Old 17-03-16, 08:28 PM
Dicehunter's Avatar
Resident Newb
Nope, Are you meant to ? With the RMi PSU I had you could press the test button any time and the fan would spin, Is it different with the AXi ?
__________________
  #4
Old 17-03-16, 08:36 PM
Grey_beard's Avatar
OC3D Elite
Yup, all cable needs to be disconnected from the PSU then hold the self test button.. of course make sure the power is plugged in.
  #5
Old 17-03-16, 08:50 PM
Dicehunter's Avatar
Resident Newb
Ok yep works fine.
Figured out what the problem is, Fan speed reducers.
I had the 3 x front intake fans and 1 x rear exhaust fan on fan speed reducers which were in turn plugged into the mobo via extension cables instead of being directly plugged into the PSU via 12v and apparently this caused some type of malfunction.
Ran same tests again and all is good.
Lesson of the day ? Do not buy cheap fan speed reducers
__________________
  #6
Old 24-03-16, 04:59 PM
Grey_beard's Avatar
OC3D Elite
Alright, cool. Good to hear its not your expensive PSU
  #7
Old 24-03-16, 05:17 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
You pudding!
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #8
Old 24-03-16, 08:08 PM
Dicehunter's Avatar
Resident Newb
Sadly it looks like it is
Originally Posted by Wraith View Post
You pudding!
Well it turns out the rig is still turning itself off and a lot more frequently now
Upon reboot the bios says -
ASUS Anti-Surge was triggered to protect system from unstable power supply unit!"
Guess I'll have to do an express RMA.
*EDIT*
Before I do anything I'm going to see if it's possibly an adaptive voltage issue as I've heard before that people have had issues with certain PSU's with X99 and adaptive voltage.
__________________
  #9
Old 24-03-16, 08:25 PM
Grey_beard's Avatar
OC3D Elite
*EDIT*
Totally not aware of this, never heard it before... Was it during X99 lauch? or more like recent?
  #10
Old 24-03-16, 08:26 PM
Dicehunter's Avatar
Resident Newb
Haven't got a scooby to be honest, Just read it on a few different forums.
It's worth a try
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
