Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 01-02-16, 03:36 PM
TheF34RChannel's Avatar
TheF34RChannel TheF34RChannel is offline
OC3D Elite
Corsair Gaming K70 RGB troubles
I'm having some troubles again, this time with my replacement keyboard; this is one needy keyboard...
- Three key LEDs are stuck on a colour
- Often the Del and PageDown (?) key don't work until I restart the system
- One keypress randomly registers as 2, giving me loads of typos
__________________
Asus Z370 MXH | 8700K 4.7GHz | Corsair H105 | G.Skill Trident Z 3333MHz CL16 16GB | Asus GTX 1080 Strix | EVGA SuperNOVA 850 P2 | Crucial MX200 500 GB | Acer XB270HU 1440p | Win10 Pro x64
We call ourselves legion, for many we be. So hand me your kingdom, I'll take it from here. And dare no one break from, my circles of fear
  #2
Old 01-02-16, 03:52 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
- Two key LEDs are stuck on a colour
I had something similar happen on my RGB K95, Push the bios switch on the back of the keyboard all the way in the opposite direction and back again.
Fixed it for me.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #3
Old 01-02-16, 07:38 PM
OC3D Elite
Gave it a go but didn't work - for the LEDs anyway.
__________________
  #4
Old 01-02-16, 09:00 PM
notcool notcool is offline
Advanced Member
I suggest contacting Corsair support they are quick to respond - https://corsair.secure.force.com/home/home.jsp remember they're on USA hours though. That is pretty much what Greybeard (the Corsair rep) will tell you to do anyway.
  #5
Old 01-02-16, 11:09 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
F34R, I haven't seen this kind of issue for a while now. But have you tried flashing again to 1.33v? You can flash it in the CUE software.
If that doesn't help, contact our support and they will walk you through on resetting the KB's memory bank. That should bring your KB back to factory settings.
  #6
Old 02-02-16, 06:02 PM
OC3D Elite
BIOS thingy didn't work for any issue, I'll contact support.
__________________
  #7
Old 02-02-16, 06:29 PM
Grey_beard's Avatar
OC3D Elite
Let me know if our support guys were able to fix it for you.
  #8
Old 07-02-16, 03:31 PM
OC3D Elite
Wee update: Corsair gave me firmware and instructions how-to*, but it didn't solve either issue. Let's see what they'll say next
*1 - Please completely exit out of the Corsair Utility Engine Software
2 - Disconnect the keyboard entirely from your system
3 - Using a paperclip, thumb tack, or thin needle, please hold down on the reset button located next to the polling rate switch
4 - As it is pressed down, please connect the keyboard to a USB 3.0 port on your system (please ensure the connector labeled with the keyboard icon is connected only)
5 - A file explorer pop-up will be displayed showing drive name as CRP_DISABLED
6 - Please ensure you first delete the firmware.bin file that is on the CRP_DISABLED drive. Transfer the K70RGB_app133_RC.bin that is attached to this ticket over to the CRP_DISABLED drive.
7 - Once transferred over, disconnect the keyboard and repeat the pinhole method to input the actual firmware and bootloader file for your keyboard (K70RGB_BLD012_App133RC.bin).
UPDATE: They said to RMA it - again... I admit I have lost faith in this keyboard completely (got the original last September, RMA'd it last October, and now again).
__________________
  #9
Old 07-02-16, 08:28 PM
avatarraq avatarraq is offline
Newbie
Can you share the files?
  #10
Old 07-02-16, 08:34 PM
OC3D Elite
Would that be allowed, and if yes, how?
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
