Thread Tools Display Modes
  #111
Old 16-11-15, 05:58 PM
sfelock's Avatar
sfelock sfelock is offline
Advanced Member
Originally Posted by Permafrost View Post
thanks mate, how your build coming along?
It's nearly finished, actually just dropped an update. I have some work to do on the PSU shroud yet, as it ended up a little out of whack when I bent it, but that and mounting the SSD is really all that is left.
__________________
Rescue 1 Build Log
Specs:
AsRock Z97 PRO4, Intel 4690k, Corsair H60 AIO, Vengenace Pro 1866mHz 2x8GB, Samsung 840 EVO 250GB, 2x XFX R7 370 in Xfire, Fractal Edison 750M, Fractal Define S, Fractal Venturi HP-12 fans
  #112
Old 17-11-15, 12:07 AM
jimma47's Avatar
jimma47 jimma47 is offline
OC3D Elite
I like the paper towel - makes me think a white false floor would look the goods and compliment the motherboard (unless I saw that on another Fractal competition rig?) It would also cover up those fan vents in the floor. If it's too much white then a stealth black floor would go well with the space in the front behind your res.
Only other comments are to consider De-stickering the top of the PSU or turn it up the other way.
Overall the build looks really good!
__________________
Rig Gallery - Krusty III
  #113
Old 17-11-15, 03:37 AM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Tom has one in the GPU test rig
I agree with TPC it's stunning fella, huge props to you for completing the loop.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #114
Old 17-11-15, 08:31 AM
tinytomlogan's Avatar
The Guvnor
The boys are right IMHO - get that PSU turned over
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #115
Old 17-11-15, 09:06 AM
Kilbane's Avatar
Kilbane Kilbane is offline
Hagrid Look-A-Like
Looking good dude. As Wraith said, well done for finishing the loop and not giving in, many props for your determination!
And, also as Tom said, turn the PSU over. Looks much cleaner without the sticker showing, I had the same issue with my RM850i in my build.
__________________
I'm not a Geek! ..... I'm an intellectual BADASS!!
  #116
Old 17-11-15, 12:26 PM
Permafrost's Avatar
Permafrost Permafrost is offline
Compo Whore
the stress is real!
it's a of a pain in the a$$ to do with the loop done, I'm thinking of putting a psu shroud
i would like to use the OC3D logo somewhere but want to run it by you first.
you joking? what happened dude?
EDIT also need to come up with a name for the pc it's self.
__________________
  #117
Old 17-11-15, 12:31 PM
The Guvnor
There plenty of room to do the PSU with the loop in there fella!
__________________
  #118
Old 17-11-15, 12:34 PM
sfelock's Avatar
Advanced Member
A psu shroud would do the trick, but I almost feel at this stage in the build it would be more work than it's worth. Especially since you have tubing that would run though it in the center.
__________________
Rescue 1 Build Log
Specs:
  #119
Old 17-11-15, 12:38 PM
The Guvnor
Just flip it over, its 2 minutes work!
__________________
  #120
Old 17-11-15, 01:16 PM
JR23 JR23 is offline
OC3D Elite
It's looking really sweet, the balance of white, black and red is great. I also think that the PSU would look better turned over. Some form of cover for the floor, an acrylic plate or just nice sound dampening foam would really complete it. Personally I think that matt black would look best so the cables and fittings stand out against it. A shroud wouldn't be that great and ending it half way along the case would be really awkward, especially with such a nice PSU and cables.
In the last picture it looks really incomplete with the LED's directly visible. I'm presuming the side panel covers them up but it's still great to see so much of the build. A side panel with a tiny frame and no glass would set it off for final pictures as either with or without the stock one in place it's a little compromised IMO.
JR
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
