Thread Tools Display Modes
  #101
Old 11-11-15, 12:51 PM
Tolemac's Avatar
Tolemac Tolemac is offline
OC3D Elite
Good work there matey
__________________
Build Log: http://forum.overclock3d.net/showthread.php?t=72241
“If you knew the magnificence of the three, six and nine, you would have a key to the universe.” – Nikola Tesla
  #102
Old 11-11-15, 06:30 PM
Permafrost's Avatar
Permafrost Permafrost is offline
Compo Whore
thank mate
just a quick question maybe a noob question..
so in the loop i'm using deionized water to clean and rinse, could i use the same deionized water as coolant if i got a silver kill coil and Mayhems Dye Deep Red concentrate?
the blocks are nickel plated copper and the rads are 90% copper tubing (H90) with Brass chambers.
thoughts guys and girls
__________________
  #103
Old 12-11-15, 07:33 AM
Asperatis's Avatar
Asperatis Asperatis is offline
Advanced Member
I wouldn't do that as you used it to clean out any leftover gunk or acrylic sawdust or w/e. You want to keep the water you're about to use as clean as possible imo even though you're going to use a kill coil and some PtNuke.
I cleaned everything with tap water and repeated the process a few times with distilled afterwards just to make sure everything was as clean as it could be.
__________________
~Nyssa~
900D - Rampage V Extreme - 5930K - 32GB Corsair 2666 DDR4 - Titan X SLI - Xonar Phoebus - AX860i - Samsung 950 Pro 512GB - Samsung 850 PRO 256GB - 1x 2TB WD Red - Custom Acrylic Loop
Build Log
  #104
Old 12-11-15, 10:43 AM
Permafrost's Avatar
Compo Whore
Oh right, I've flushed the for a 2nd time and still have over 2 litres of deionized water left. I was thinking about using it as coolant as there are so many mixed opinions about it.
__________________
  #105
Old 12-11-15, 10:45 AM
Warchild Warchild is offline
OC3D Elite
I see no problem, as long as what you put into your loop is clean and not what you used to flush the system.
Purity is important so you dont want any foreign objects or contaminants.
  #106
Old 15-11-15, 10:54 AM
Permafrost's Avatar
Compo Whore
update: the first casualty of the build is my EVGA sli bridge
the led is dead as I tried to disassemble it for painting
__________________
  #107
Old 16-11-15, 05:12 PM
Permafrost's Avatar
Compo Whore
update: leak testing the loop done all good
other then the cables what else do you guys think I need to do?
__________________
  #108
Old 16-11-15, 05:36 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
Maybe small stuff like custom stickers for the fans, a red snowflake instead of the blue? But other than that it looks gorgeous!
  #109
Old 16-11-15, 05:42 PM
sfelock's Avatar
sfelock sfelock is offline
Advanced Member
Looking good dude.
__________________
Rescue 1 Build Log
Specs:
AsRock Z97 PRO4, Intel 4690k, Corsair H60 AIO, Vengenace Pro 1866mHz 2x8GB, Samsung 840 EVO 250GB, 2x XFX R7 370 in Xfire, Fractal Edison 750M, Fractal Define S, Fractal Venturi HP-12 fans
  #110
Old 16-11-15, 05:48 PM
Permafrost's Avatar
Compo Whore
awesome idea! i'll look into that!
Originally Posted by sfelock View Post
Looking good dude.
thanks mate, how your build coming along?
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
