Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 19-08-15, 10:27 AM
tinytomlogan's Avatar
The Guvnor
Originally Posted by TPC View Post
my noob brain would say put them closed to the PSU.
Half way along behind the motherboard has been decided
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #12
Old 19-08-15, 04:00 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by tinytomlogan View Post
No need to worry - Im the reason for the delay. The reason is the caps. Cablemod will probably have cables out before Corsair. Ive already had two different colours here and had them on the PSU tester.
As the caps are only on the CPU, PCI-E and 24 pin cables do you think they will sell them separately or will I have to buy a whole new pack you think ?
Also do you recommend putting the stock cables PCI-E and CPU cables back on ?
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #13
Old 19-08-15, 04:09 PM
MadShadow MadShadow is offline
OC3D Elite
So is Corsair the first to implement this or has it been done before?
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #14
Old 19-08-15, 04:11 PM
Dicehunter's Avatar
Resident Newb
Silverstone have also done it on their Strider series of PSU's although I'm not aware of any others.
__________________
  #15
Old 19-08-15, 04:51 PM
The Guvnor
AFAIK there should be an 'RMi' kit available to add into other Corsair kits that have been bought. Its a bit of a SKU nightmare tbh
__________________
  #16
Old 19-08-15, 05:21 PM
Dicehunter's Avatar
Resident Newb
I can imagine yeah, It's not that bad though if the price is going to be reasonable.
Personally I'll need to get the 24 pin, 8 pin CPU and 3 x 6+2's, Hoping the price from Cablemod won't be that insane
__________________
  #17
Old 20-08-15, 05:20 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
This is lovely and all, but why didn't you just save everyone the trouble, and put the caps on the inside of the PSU before the outgoing connectors to save everyone the headache and messy cables?
I honestly don't see the logic?
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #18
Old 20-08-15, 05:22 PM
OC3D Elite
mind=blown
But actually, that sounds like a good idea
__________________
  #19
Old 20-08-15, 05:44 PM
Dicehunter's Avatar
Resident Newb
Hopefully Grey_Beard can enlighten us, There must be a logical reason why the caps are on the cables instead of inside the PSU
__________________
  #20
Old 20-08-15, 06:07 PM
JR23 JR23 is offline
OC3D Elite
So the ripple suppression still isn't as good as an AX1500i which didn't need them? I don't get it.
JR
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
