Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 18-08-15, 05:48 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Explanation of RMi's New Type 4 Cables
Most of you probably already know, but for those who are wondering why our RMi PSUs have an excellent ripple suppression, the answer in the cables.
RMi's Type 4 Cables
  #2
Old 18-08-15, 06:55 PM
MadShadow MadShadow is offline
OC3D Elite
Very cool, I wouldn't have thought of that. Is that something new or has it been done before?
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #3
Old 18-08-15, 08:04 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Does this only apply to the 24 pin ?
Just curious as I'm not sure Cablemods replacement pack has taken this into account for the rest of the cables, I know they still need to bring a compatible 24 pin out.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #4
Old 18-08-15, 08:41 PM
Grey_beard's Avatar
OC3D Elite
The additional solid capacitors are added on the 24pin, PCI-E, and EPS cables.
I'm sure that Cablemods is well aware of those caps, just not sure if they have taken them into account with their verison.
  #5
Old 18-08-15, 08:48 PM
Dicehunter's Avatar
Resident Newb
That's a little worrying.
Might have to switch back to the stock Corsair cables just incase and until Cablemod gets back to me.
Knew I should have gone with the official Corsair replacement kit
__________________
  #6
Old 19-08-15, 08:03 AM
tinytomlogan's Avatar
The Guvnor
No need to worry - Im the reason for the delay. The reason is the caps. Cablemod will probably have cables out before Corsair. Ive already had two different colours here and had them on the PSU tester.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #7
Old 19-08-15, 08:10 AM
Doomslayer Doomslayer is offline
OC3D Elite
That's good to know TTL
  #8
Old 19-08-15, 08:26 AM
Grey_beard's Avatar
OC3D Elite
Most likely, because we still don't have an ETA for ours.
  #9
Old 19-08-15, 08:35 AM
The Guvnor
They were going to pump them out without the caps until I said if they did I would put something live showing the difference in performance, all we have been working on since is the best place to put them along the cable
__________________
  #10
Old 19-08-15, 10:17 AM
TPC's Avatar
TPC TPC is offline
OC3D Elite
my noob brain would say put them closed to the PSU.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
