Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 06-06-15, 09:27 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by tinytomlogan View Post
More than likely all the things considering I got told "stupidly busy times for you after computex"
Awesome sauce
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #12
Old 07-06-15, 07:40 AM
Yeungster Yeungster is offline
OC3D Crew
Sorry to jump over your post Dice but having only just seen this, what are the key advantages of the H110i GTX over the H110i GT?
Looking at the specs from the Corsair website in isolation, the H110i GT appears to have higher airflow fans due to greater RPM and a larger rad?
H110i GT
Radiator dimensions: 140mm x 322mm x 27mm
Fan dimensions: 140mm x 25mm
Fan speed: 2100 +/- 10% RPM
Fan airflow: 113 CFM
Fan static pressure: 3.99mm-H2O
Noise level: 43dB(A)
H110i GTX
Radiator dimensions: 140mm x 312mm x 26mm
Fan speed: 2000 +/- 10% RPM
Fan airflow: 104.65 CFM
Noise level: 40 dB(A)
  #13
Old 08-06-15, 08:34 AM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Dice, sounds like you ready to slap the HG10 on that Titan X
No official word atm as to when they are going to be available for purchase. I don't think that we've started mass producing yet, so I'll give it a couple before it becomes widely available.
Nothing really in particular, except for some minor physical differences like the coldplate shape and the way the tubes are connected. In terms of performance, they are going to be essentially identical. In some cases, H110i GTX may have the slight edge over the GT because of the wider rad spec , but it won't be massive.
  #14
Old 08-06-15, 08:40 AM
Dicehunter's Avatar
Resident Newb
Cooleo thank you
__________________
  #15
Old 25-06-15, 02:46 PM
Dicehunter's Avatar
Resident Newb
For anyone interested I just found out the 980 Ti/Titan X HG10 bracket will be available around August
Gonna be going with that instead of the EVGA AIO, This way I can keep everything inside my rig Corsair
__________________
  #16
Old 25-06-15, 06:15 PM
Grey_beard's Avatar
OC3D Elite
Sounds like a great plan to me
  #17
Old 25-06-15, 06:27 PM
Dicehunter's Avatar
Resident Newb
The only 2 things that aren't Corsair in my rig are the memory and PSU, Sorry but in those 2 departments Avexir and Superflower won me over
Nearly everything else is Corsair though, SSD's, CPU Cooler *Soon to be replaced with an H100i GTX so I can reuse my existing 120mm Corsair LED fans*, Fans, Case, Mouse, Keyboard, Mousemat, External speakers and soon the HG10 which I'll stick an H90 on it with a 140mm White LED SP fan.
And in the words of Gollum -
__________________
  #18
Old 25-06-15, 06:38 PM
Grey_beard's Avatar
OC3D Elite
Really dude? I'm sure you've seen dem RM's right? TTL's review on that is one of the best one.
  #19
Old 25-06-15, 06:42 PM
Dicehunter's Avatar
Resident Newb
Performance wise there's not much between them plus there's a reason all the top overclockers use Superflower
Not forgetting to mention DEM LOOKS !!!
__________________
  #20
Old 25-06-15, 06:49 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
Money?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
