Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 16-03-15, 05:37 PM
Ryan_uk Ryan_uk is offline
Newbie
H100i GTX - Faulty Pump?
Finally got my hands on this after waiting almost a month after ordering for it to re-stock only to be pretty disappointed.
Kit itself looks the part but unfortunately the pump from the get go has been making an awful lot of noise , what I can only describe as an electric shaver type buzz.
Edit: My own vid showing what I get on Quiet mode.
Pretty annoying considering idle temps are 25°c on my 4790k, so it's plodding along doing it's job nicely, just incredibly loudly.
Any possible tips or solutions or should I just RMA the fella asap.
Edit: Corsair forum thread with guys experiencing similar problem.
http://forum.corsair.com/v3/showthread.php?t=138677
  #2
Old 16-03-15, 05:51 PM
tinytomlogan's Avatar
The Guvnor
Have you got it hooked up to the link software?
If you have try setting the pump to quiet mode - should solve it
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 16-03-15, 05:56 PM
Newbie
Yup, all hooked up to Link.
Been on Quiet mode the whole time, sitting at 1700 RPM or so. Performance mode can be heard from another room almost.
  #4
Old 16-03-15, 06:04 PM
The Guvnor
Had probably best wait for Mr GreyBeard to comment on it then dude
__________________
  #5
Old 16-03-15, 06:05 PM
Newbie
Righto , cheers Tom
  #6
Old 16-03-15, 06:46 PM
The Guvnor
Moved this to the Corsair forum so GreyBeard can see it
__________________
  #7
Old 16-03-15, 08:17 PM
Pr3d4t0r Pr3d4t0r is offline
OC3D Elite
I know some h100 and h100i had an issue where the pump was getting too much voltage and making horrid noises, that was generally fixed by adding a small resistor to power cable. But probably better to RMA it instead of messing around with it
__________________
MSI Z97 Gaming 7, i7 [email protected], Palit Super Jetstream GTX 980ti, 16GB Corsair Vengence [email protected] 9/10/9/10/26 , Corsair HX850i, NZXT H440 grid+, Corsair H100 Push nff12, AF140 outake 5.6v, 3xsp120 intake 5.6v 250gb 840evo boot, 120gb V300 games, 1tb wd black storage||| 3Dmark score
  #8
Old 17-03-15, 08:57 AM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Thanks for assisting Tom.
@Ryan - Thanks for bringing this up to our attention right away.. it gives us a head start to investigate and find out what's causing the noise. Both our dev team and validation team are already aware of this unusual behavior, we'll provide an update once we have a more definitive diagnosis.
  #9
Old 17-03-15, 01:55 PM
Newbie
Great thanks Grey , would be lovely if it was a simple fix, as like I said it's cooling away nicely, just dont wanna hear it through my headphones!
If it helps at all , it's running on a Maximus VII Hero with Windows 7.
  #10
Old 17-03-15, 05:09 PM
Grey_beard's Avatar
OC3D Elite
No problem at all. That's what I am hoping as well, a simple fix..no worries though, we are on top of this already and working on finding out the root cause. Fwiw, I have the H80i GT myself and I don't have this pump noise, so there is a chance that this is just an isolated case.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
