Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 19-12-14, 04:25 AM
The_Governour's Avatar
The_Governour The_Governour is offline
OC3D Crew
Originally Posted by Chrazey View Post
Umm... distance under a standard 780?, sorry, but can't help you on that front since I have an 6950 in there.
Are the cards more or less a standard size from the floor to the bottom of the card? Even so with your 6950 how many cm is there of space?
  #12
Old 19-12-14, 05:15 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
I'll take a look tonight when I get back from work for you, unless you've gotten a reply already untill then
  #13
Old 19-12-14, 06:38 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
I actually had another case in mind before this one, which was the Corsair Graphite 380T, which I will switch to next week hopefully... I'm just a more mesh type of guy, I like the handle on the 380T, and that it's basically only mesh.
And the main reason for it, is that I can fit my H100i in there and still have my 200mm fan, which I unfortunately can't in the 250D.
Hope that answered your questions
It did, Thank you. 380T is not a bad choice at all. It's a more open air case design compared to the 250D. And yes, that handle does come in handy when you move the case around.
  #14
Old 20-12-14, 10:05 PM
OC3D Crew
So mate? got some numbers?
Tags
250d, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
