Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 16-09-14, 02:40 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
780T long scratch on window
After my 780T arrived today I noticed upon unpacking that the window arrived with quite a long and large thin scratch from the bottom right to the top left on the inside of the window.
Can anything be done about this ? I don't really fancy sending it back because of a scratch on the window but it's driving me nuts.
It looks like someone at the factory had a bad day and ran a screw driver along it
Any DIY solutions able to fix this ?
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #2
Old 16-09-14, 02:51 PM
jaspervandervalk's Avatar
jaspervandervalk jaspervandervalk is offline
Member
Hey Dicehunter,
I once had a problem with a 600T a few years back, I wrote an e-mail to Corsair explaining my problem and they actually straight up sent me a new side panel for that side. However at that point they did sell side panels as a separate component of the case.
In terms of DIY fixes I would not recommend anything other than trying to scrub the scratches with a slightly damp NEW sponge (to avoid any sand being in it and scratching it further!) and some polishing cream.
I have a friend who once tried to fill the scratch with glue dabbing it on with cotton wool buds and then buff away the excess again using a wet sponge and polish, it looked alright but light still refracted off the crack... which wouldn't look too good if you're a perfectionist.
Regards, Jasper.
  #3
Old 16-09-14, 03:42 PM
paulstung's Avatar
paulstung paulstung is offline
OC3D Elite
I'd contact George he is normally on the ball with this sort of thing, I'd be in the same mind in not sending it back because of a scratch. How deep is it, I no you said thin scratch, if it is uber thin maybe some TCut might work ?
  #4
Old 16-09-14, 04:08 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Boys have we all become blind... Dicehunter has posted this in the Corsair Customer Care forum, advice really isn't required.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #5
Old 16-09-14, 04:13 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Nothing wrong with giving some tips as they might help him and not make any sort of action from Corsair necessary imo.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #6
Old 16-09-14, 05:04 PM
Dicehunter's Avatar
Resident Newb
Well I got in touch with a guy over at MNPC tech *King of modding* and he said anything over 1mm is pretty much not worth it in terms of trying to fix it as it will leave the window with a noticeable foggy patch, Just replace it.
I've submitted a ticket and I'll see what Corsair say.
__________________
  #7
Old 16-09-14, 07:43 PM
BigBlue1 BigBlue1 is offline
Banned
If you are stuck with the scratched one, use the stainless cleaner and polish from Weiman and it will make it a lot less noticeable keep it dust free longer too.
  #8
Old 16-09-14, 07:44 PM
Dicehunter's Avatar
Resident Newb
Thank you lady blue, I'll go buy some if Corsair can't help me
__________________
  #9
Old 17-09-14, 02:53 PM
Dicehunter's Avatar
Resident Newb
Thanks to Tom for recommending the Novus scratch and polish kit, I've done a bit of research and watched a few videos and the stuff really seems to work.
£20 for the complete kit and what I don't use which I wont be using a lot I can keep for the future
Just ordered it from amazon for £20 inc postage, You can get it on the bay but it's imported from the US and costs £13 pound for postage.
For anyone that's interested
And a video showing how effective it is on plastic surfaces -
__________________
  #10
Old 17-09-14, 07:50 PM
Banned
I have seen that product used on old plastic headlight covers, it is adequate.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
