Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #21
Old 23-09-14, 05:34 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Originally Posted by Xrqute View Post
Are you sure?
http://www.pccasegear.com/index.php?...9069&cPath=511
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #22
Old 26-10-14, 08:10 AM
Etlar Etlar is offline
OC3D Crew
I will like to hear, if you can use more then one Corsair commander in the same rig ? If my plads go like i will, then i will need two of them. But will they work Grey ?
  #23
Old 27-10-14, 08:20 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Corsair link SW will only recognize one unique Commander ID at the time. If you add a second one, it'll just act like a hub for your fans and LED strips with no control over them.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
