Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #21
Old 31-07-14, 06:58 PM
BlueScreen BlueScreen is offline
Member
Originally Posted by Dicehunter View Post
A lot of people including myself buy back lit keyboards because this makes seeing the keys at night more comfortable on the eyes rather than having a hugely blurring light overhead or on your desk and seeing as I do a lot of my work at night this helps
With a little ingenuity you can solve this problem.
I personally do not like LEDs on expensive things, as they are most likely component to die long before everything else goes down. That in itself is frustrating, let alone crappy support from alot of manufacturers that you have to bear with for sometimes very long period of time. And even if service provided is of high quality, that still leaves you without a keyboard for a few days.
But then again I never was a huge fan of things with unnecessary bling bling.
  #22
Old 31-07-14, 07:13 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Care to elaborate on this ingenuity ?
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #23
Old 31-07-14, 07:39 PM
Member
oh, it really depends on your setup.
There are LED stripes that make fine light sources, especially if your keyboard sits neatly on a shelf. Or something as simple as led spot lights that you can buy in ikea for dirt cheap. For me it is much more convenient as its very easy to fix should anything go wrong. Without having to rely on any company.
  #24
Old 31-07-14, 08:18 PM
Dicehunter's Avatar
Resident Newb
Now that you mention it LED strips would be quite handy, Thanks for the advice
__________________
  #25
Old 16-08-14, 12:59 AM
Permafrost's Avatar
Permafrost Permafrost is offline
Compo Whore
update from Corsair:
now saying there not going to have the keyboard in stock till the 29th.
I truly have given up now
and now i'm looking to buy a new keyboard from somewhere else
  #26
Old 16-08-14, 05:28 AM
SUPERFLY013's Avatar
SUPERFLY013 SUPERFLY013 is offline
Member
Sorry for the bad luck mate.. Had the same thing happen to be with my k90 about 2 months after I got it. I rma'd it and got the same message as you did. I was stuck using a crappy compaq keyboard from and old computer I had gotten ages ago. But I just held in there and corsair delivered. I have not had any problems since then. If I was you, I would possibly contact maybe or just hold on a little while longer. If you can't there's always logitech. Heard good things about their keyboards. ( I have only used there wireless gaming mice)
__________________
My PC specs-
CM Storm Stryker
Gigabyte 990x ud3
AMD FX6100
Asus 7870
Nzxt Hale 90 750W
16GB of Corsair Xms3
NZXT Kraken X60
  #27
Old 16-08-14, 07:34 AM
Dicehunter's Avatar
Resident Newb
and now I'm looking to buy a new keyboard from somewhere else
To avoid future inevitable Corsair LED death and death in general just go with Ducky, Sell your replacement when you get it and put the funds towards the Ducky, It's what I did.
It's pretty much indestructible and it's no good waiting for their RGB lineup as apparently a certain reviewer got a sample and there were dead LED's on it.
Ducky Shine 3 -
__________________
  #28
Old 16-08-14, 07:36 AM
Member
To avoid future inevitable Corsair LED death just go with Ducky, It's pretty much indestructible and it's no good waiting for their RGB lineup as apparently a certain reviewer got a sample and there were dead LED's on it.
Ducky Shine 3 -
I second ducky. Can't believe I forgot about them.
__________________
My PC specs-
CM Storm Stryker
Gigabyte 990x ud3
AMD FX6100
Asus 7870
Nzxt Hale 90 750W
NZXT Kraken X60
  #29
Old 16-08-14, 07:39 AM
Dicehunter's Avatar
Resident Newb
Heathen...
They are out of stock at the moment but they are very popular due to their rugged nature, Stock is replenished quickly -
http://www.overclockers.co.uk/showpr...702&catid=2705
__________________
  #30
Old 16-08-14, 12:25 PM
Permafrost's Avatar
Compo Whore
tbh the thing that really pi**es me off is they know which retailer has them in stock so why can't they send out E-vouchers or people but the new item then send them the invoice and they refund the person on said item?
Ducky Shine 3 -
the funny this is i was going to go for that one till i saw the K60 and the K60 was cheaper lol
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
