Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #21
Old 13-05-14, 12:53 PM
ander01se ander01se is offline
Member
I refuse to say d*ne, so... Finished! :O
  #22
Old 13-05-14, 12:58 PM
WYP's Avatar
WYP WYP is offline
News Guru
Done!
__________________
_______________________________
Twitter - @WYP_PC
  #23
Old 13-05-14, 01:01 PM
kenny01924 kenny01924 is offline
Member
Send a message via Yahoo to kenny01924
done it
  #24
Old 13-05-14, 01:05 PM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
done!
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #25
Old 13-05-14, 01:21 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Done.
And I completely agree with SuB on this. Less is definitely more.
Originally Posted by SuB View Post
tool-less stuff should be completely 100% abolished in high-end cases. If you can afford the case, you don't need fancy clips and stupid no screwdriver builds. I'm far happier with high quality screws than any quickly designed molded plastic clip..
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 16GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #26
Old 13-05-14, 01:31 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Done.
Additionally, I have a 730T and it's a brilliant case apart from 2 issues I have.
1) There aren't dust filters on the fan mounts which is disappointing.
2) Annoyingly my PSU doesn't fit with the fan facing down as the fan guard gets in the way. If I remove the fan guard it then fits but produces an audible vibration due to lack of soft mounting pads (which my previous case, the CM Stryker had).
__________________
Enthoo Elite | i9-7900X | Rampage VI Extreme | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | PG279Q, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #27
Old 13-05-14, 04:45 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Much appreciated guys .. keep em coming! I've taken down some notes. I have to say, some of these suggestions does make perfect sense
Is that the AX860 in your sig? Create a separate thread for it and I'll take a look
  #28
Old 13-05-14, 04:54 PM
RickPlaysWarr's Avatar
RickPlaysWarr RickPlaysWarr is offline
OC3D Crew
Finished survey
Current case Obsidian 250D/H100i. Love it 2 ssd, and can boot Win 7/osX
10.9.2
Next rig will be first full water-cooled custom loop based around ASUS Maximus VII Hero board.
Please no more 5.25 bays in front. Have not used one in years.
__________________
  #29
Old 13-05-14, 05:12 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
Done!
__________________
  #30
Old 13-05-14, 05:17 PM
MadShadow MadShadow is offline
OC3D Elite
Originally Posted by RickPlaysWarr View Post
Finished survey
10.9.2
on this
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
