Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 02-01-14, 12:14 PM
Pogal_31's Avatar
Pogal_31 Pogal_31 is offline
Advanced Member
Send a message via Skype™ to Pogal_31
Don't know if that can be helpfull, but i got the same problem with mine, running Windows 7. H100i was not recognized in my Corsair link, so I swapped the header on another USB port and that was fixed, fully recognized and no trouble anymore.
  #12
Old 02-01-14, 05:18 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
Or that ^, but in this case, OP is using Windows 8 where this detection issue is pretty well known and something that we have acknowledged. Changing USB header is something that we have recommended to those who are using Windows 7, but something Windows 8 users can try as well.
  #13
Old 15-01-14, 02:00 PM
paullongy326's Avatar
paullongy326 paullongy326 is offline
Newbie
guys I had same problem after doing the tweak it still didn't work until I removed the software then reinstalled the software and amazing the tweaked worked mines all working leds colour everything working fine after reinstall
this was the reg edit thing http://forum.corsair.com/v3/showpost...0&postcount=19
__________________
CASE=CORSAIRA540~~~CPU=5820K~~~GPU=EVGA~GTX ~~980ti ~~ CLASSIFIED ~~ ACX ~~~
SSD SAMSUNG 850 EVO 500GB~~ SSD 250 GB SAMSUNG 840 PRO ~~~MEMORY=DDR 4 DOMINATOR PLATINUM~3000MHZ~~~MONITOR=Dell U2715H 27" QHD IPS Monitor 2560x1440~~M/B=ASUS X99 PRO
  #14
Old 17-01-14, 11:02 PM
Grey_beard's Avatar
OC3D Elite
Glad to hear that Paul. Part of me sometimes wishes that we make this tweak an official fix, unfortunately, does not work that way. We don't feel comfortable asking our customers to edit their Windows registry. C Link should work on the fly without any modification.
  #15
Old 10-02-14, 02:41 AM
bigdaddy5414's Avatar
bigdaddy5414 bigdaddy5414 is offline
Member
Will have to try this beta software. My H100i worked fine on 8 but now with 8.1 it's a no go.
Update: Works perfect. Now my temps dropped nearly 10 degrees Folding @ Home.
  #16
Old 10-02-14, 10:51 PM
Grey_beard's Avatar
OC3D Elite
Cool Glad to hear that you've got it all figured out
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
