Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #31
Old 23-09-13, 04:57 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Originally Posted by Grey_beard View Post
AFAIK, there is only one type of SSD cage for the Air 540. You are referring to this one right?
What about the 350D SSD cage? Seems like a somewhat different looking design but has the same function?
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #32
Old 23-09-13, 05:26 PM
Grey_beard's Avatar
Grey_beard Grey_beard is offline
OC3D Elite
They are the same design, but the one for the Air 540 is a 4 SSD tray and the one for the 350D is 2 SSD tray. Corsair 350D SSD cage.
  #33
Old 23-09-13, 05:37 PM
FTR.4500MHz's Avatar
FTR.4500MHz FTR.4500MHz is offline
OC3D Elite
The 350 and 540 trays are a bit different tho based on the same design. The 540 trays were made taller to be able to connect every ssd with a 90° connector which iirc was a problem on the narower 350 trays.
__________________
Hardware: Shinobi XL w.custom window | Msi Z77A-GD65 | i5 3570k | 8GB Corsair Vengeance 1600MHz | 7970 Lightning BE | AX 850 | SSD's: Samsung 830 128GB , Corsair Force GT 120 GB | HDD: Seagate Barracuda 750 GB | XonarD2X | Edifier S730 | iiyama prolite g2773hs-gb1 |
Watercooling: EK supremacy p/n | EK 7970Ltg. a/n | D5+EK Top | UT60 360 and 240 rads | EK X3 150 res. | Tygon 13/19mm | Bitspower C.fittings |
  #34
Old 23-09-13, 08:15 PM
GoogalyMoogaly GoogalyMoogaly is offline
Member
Seems like he might have been sent the 350 cage then as they said the drives could be closer together.
I hadn't thought about the right angle connector, I'd imagine that'd be awkward either way in the 540, but could see why it'd be an issue in the 350.
  #35
Old 15-11-13, 04:19 PM
alphan3rd alphan3rd is offline
Newbie
I would like some suggestions on better exhaust methods when it comes to EVGA GTX 770 Classi's.....
Current set-up:
Just received 2 replacement doors so I'm really open to suggestions now.... Should I go with 2 120mm fans being that the hole size is 5 inches and I can buy a hole saw that is 5"..
The hole in the first image was hand cut and filed which was a pain and not to mention, the big fan doesn't move much air.
Please/Thank you [email protected]
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
