Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #1
Old 05-10-12, 06:10 PM
Bocephus Bocephus is offline
Advanced Member
MS Outlook help please?
I just installed outlook on my new Win7 desktop. I am having problems figuring out how to get my inbox folder from my old XP outlook to my new Win7 outlook...2 different desktops. All mail that i save is in a hierarchy system.
Any help would be greatly appreciated
__________________
Forum chat is just that...it's not a doctorate on correct grammar.
  #2
Old 05-10-12, 06:38 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
You should just be able to import or copy the .pst file from XP into 7. Are the the same versions of outlook?
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 16GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #3
Old 06-10-12, 01:58 AM
Goldskis45 Goldskis45 is offline
OC3D Crew
The new versions can accept all the old files back to version 2.3 or something... so you should (like ^he said) copy and paste... Its what I did when my boss gave me my new workstation... from xp to 7... personally i don't like outlook that much... but I'm warming up to the new version...
  #4
Old 06-10-12, 08:43 AM
Dagrem Dagrem is offline
Newbie
On your Windows XP machine go to Control Panel and then Mail and hit the Data File button. You should now see the path of where your pst(s) are. Go into Windows Explorer and browse to those paths. Copy your pst to a USB stick and then copy to your Windows 7 machine and make a note of where you copied it to
Go into Control Panel and then Mail and then Data File and you can click on the Add button to add you "old" pst. Open up Outlook and you should be able to see your old emails, etc by clicking on personal folder that you just added.
If you old Outlook was 2002 or older, you might want to copy your old emails over to your new personal folder so that you are not limited to the 2GB limit.
  #5
Old 10-10-12, 02:50 PM
WiganflightsimSteve's Avatar
WiganflightsimSteve WiganflightsimSteve is offline
Newbie
I have a very similar problem here. I made the mistake of trusting Windows easy transfer to save the emails/ contacts/ and some important drafts on the Pc i built for my mum. She had asked me to install XP 64bit originally, but i insisted she let me upgrade it to Win 7, when it was done it had transfered all the pictures and internet favourites, but somehow failed to move over her contacts or messages. It also didn't move over any of her music, just the blank links.
Now i have this old Pc file and i was wondering if there was any way of accessing it to pull the lost files out if they are there?
__________________
AMD FX 9590
MSi 990FXA-GD80
4 x 4Gb Corsair Vengeance DDR3 1600Mhz
msi R7970 3Gb Twin Frozr Lightning
Corsair Force 3 240Gb SSD
XFX Pro 1250w modula psu
HAF 932 case
Windows 8 Pro running X-plane 10
  #6
Old 30-10-12, 01:48 PM
neoguyver1 neoguyver1 is offline
Member
Forget pop go imap once you go imap you'll never go pop!
__________________
i7 2600k, Hyper 612S, 8GB Patriot Viper Extreme 1866Mhz, Gigabyte Z68AP-D3, 7950 3gb oc sapphire, ZALMAN Z11, Antec TP-750.
  #7
Old 30-10-12, 05:02 PM
Newbie
I didn't rate the Imap account, for some reason it was often disconnecting. Went back to POP and no problems. I was shocked that nobody on here had a solution to my issue posted above! I was sure there was a way, but just don't know what that is myself. :-/
__________________
AMD FX 9590
MSi 990FXA-GD80
HAF 932 case
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
