Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #1
Old 10-09-12, 11:52 PM
mrapoc mrapoc is offline
OC3D Elite
Backing up program
Hello
I've just got a NAS solution sorted. Excellent.
Now I want to setup a folder for each user for just dumping their stuff. Sorted easily enough with a network drive.
Now I think the best solution then is to have a folder for each user for backing up various stuff..such as my pictures.
My synology did come with a program called replicator or something but its not really flexibile and was hoping somebody knew of a (hopefully free) program to help me out.
I'd like compression and incremental (only backup when changes occur such as deletion, modification or additions) but also allowing different backup restore points. So in case I accidentally delete something and think a couple of days later...oh shiiii! I can get it back. It then needs to delete older versions after x amount etc.
Any ideas or am I looking at acronis...
  #2
Old 11-09-12, 11:29 AM
OC3D Elite
Just tried acronis true image.
It does pretty much exactly what I need.
Pricey though!
  #3
Old 11-09-12, 12:00 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
Have you already bought it? Or just using a trial?
  #4
Old 11-09-12, 12:01 PM
OC3D Elite
Trial
Just looking at easeus backup now.
Seems the same only cheaper
  #5
Old 11-09-12, 12:07 PM
Kyze's Avatar
Kyze Kyze is offline
Member
I think the money spent on Acronis is well worth it in the case of hardware-failure or dataloss!
__________________
My Rig in the Gallery!
  #6
Old 11-09-12, 12:09 PM
andrewmchugh's Avatar
andrewmchugh andrewmchugh is offline
OC3D Crew
Not thought of managing it yourself for free. Using batch files with robocopy on windows or shell scripts for mac/linux using rsync?
The above method is already installed on your machine.
__________________
| Intel Core i7 5930K | EVGA x99 Micro | EVGA GTX 980 SC ACX |
| Corsair AX 860i | 16GB Corsair Vengeance LPX |
| Fractal Design Node 804 Black | H105 |
>> build(98%) << - gallary(soon)
  #7
Old 12-09-12, 09:25 AM
OC3D Elite
Just though i'd update the thread and say I think i've found a decent solution.
Freefilesync seems to sync all changes (inc deletions) to a folder of your choice. But any files that change or deleted are kept in a versions folder. I'm going to use this as a "recycle bin" so to speak just in case.
You can set it to keep so many file revisions too. Free and simple!
  #8
Old 30-10-12, 01:45 PM
neoguyver1 neoguyver1 is offline
Member
try cobian works across the network.
http://www.cobiansoft.com/cobianbackup.htm
used in an office for specific folders to backup at luchtimes, nice options and easy interface.
__________________
i7 2600k, Hyper 612S, 8GB Patriot Viper Extreme 1866Mhz, Gigabyte Z68AP-D3, 7950 3gb oc sapphire, ZALMAN Z11, Antec TP-750.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
