Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
Thread Tools Display Modes
  #21
Old 18-01-12, 04:24 PM
Henrik's Avatar
Henrik Henrik is offline
Member
I'm sorry for you m8..
I have also done some reading on "safe" volts for the SB. There are allot of forum threads out there where people are stating that 1.52V is safe for SB. Just because they read a Max Vcore in the Intel document. Now where on page 80 of the following documenthttp://www.intel.com/content/www/us/...datasheet.html) stats that it is SAFE. It only stats that 1.52v is the max voltage.. In other words i believe it is the max voltage you CAN run before damage will most likely accrue. That dose not mean electromigration is not present up to 1.52V... We all know that you will degrade a CPU faster with higher volts or/and higher temperature. Witch means electromigration is dependent on temperature and voltage. Then why dose not Intel specify a max SAFE voltage?... I think its because every CPU is different and they will not all degrade at the same speed at higher Vcore. Some degrade very fast other not as bad.
If you would have asked me I would think that 1.4V will not degrade your chip within 1,5 year period. You must have had very bad luck m8.
__________________
My Rig
CPU: Intel 3930k @ 4,6Ghz
Motherboard: Rampage 4 Extreme
Ram: Crucial Ballistix 1600Mhz 4x4GB
GPU: EVGA GTX580
OS Drive: Corsair force GT 120GB
3930k @ 5.2Ghz
  #22
Old 18-01-12, 10:54 PM
mrDMxtreme mrDMxtreme is offline
OC3D Crew
Originally Posted by Henrik.L;[url="tel:1326907452"
1326907452[/url]]
I have also done some reading on "safe" volts for the SB. There are allot of forum threads out there where people are stating that 1.52V is safe for SB. Just because they read a Max Vcore in the Intel document. Now where on page 80 of the following documenthttp://www.intel.com...-datasheet.html) stats that it is SAFE. It only stats that 1.52v is the max voltage.. In other words i believe it is the max voltage you CAN run before damage will most likely accrue. That dose not mean electromigration is not present up to 1.52V... We all know that you will degrade a CPU faster with higher volts or/and higher temperature. Witch means electromigration is dependent on temperature and voltage. Then why dose not Intel specify a max SAFE voltage?... I think its because every CPU is different and they will not all degrade at the same speed at higher Vcore. Some degrade very fast other not as bad.
1.39v for about 10 days unlucky for sure (because temps were not high) but I guess 5ghz was too much for the chip to handle [email protected] for long periods of time...... Oh well now I know for next time right
__________________
Main Rig: Maximus IV Extreme-Z -- GTX 580 Matrix -- 2500k -- 8GB ripjawsX -- 240GB vertex4 -- CM Silent Pro 1200W -- in a CM HAFX -- cooled by a Raystorm block -- XSPC RX360 rad -- D5 pump -- XSPC dual-bay res
  #23
Old 19-01-12, 12:52 AM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
what was the temps at you keep saying not to high but it may assist others. So spill it mate what were the temps at lol
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #24
Old 19-01-12, 08:09 AM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Lol + 1.
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #25
Old 09-02-12, 02:20 PM
CBGODINGG CBGODINGG is offline
Newbie
I'm more curious about his PLL voltage; I've heard exceeding 1.85v will degrade a chip in about a week. Currently I'm ting my pants because I'm at work, and my pc is priming at 1.4v at home, and if 1.4v causes 10 day degradation, then FML. But if his problem was excessive PLL voltage, then I'm okay.
  #26
Old 09-02-12, 03:37 PM
MaXiMiZe MaXiMiZe is offline
OC3D Crew
Lol + 2
  #27
Old 12-02-12, 06:14 PM
OC3D Crew
haha sorry, i haven't been on here in a bit well my temps where in the range 60-65C (depending on room temps), which is pretty low i would say
i didn't touch PLL voltage at all, the only voltage i changed was the core voltage and on the memory i think i put 1 step over 1.5v just to make sure it was stable since i decreased the 2N or whatever to 1.
as for your chip, it just depends on the silicon lottery i guess
__________________
  #28
Old 14-02-12, 02:49 PM
Newbie
That's scary stuff =/
I dropped to 4.9GHz because of this thread, because I know I can run that under 1.37v, and I see no difference between that and 5.0.
  #29
Old 14-02-12, 05:49 PM
DB006's Avatar
DB006 DB006 is offline
Member
It's not volts that kills CPU, or is safe/not safe, it's heat.
If you want to pump 1.7v through your CPU, good luck in keeping it cool.
The only official line from Intel was 1.52v, and many benchmarkers and myself exceed that perfectly fine.
__________________
  #30
Old 14-02-12, 06:12 PM
lewwatt's Avatar
lewwatt lewwatt is offline
Member
Voltage does degrade the CPU even if you can keep it cool. If I find the source I'll edit it into this post.
__________________
Specifications
Intel [email protected] // MSI N680GTX
ASRock Extreme3 Gen3
// Corsair Vengeance 16GB
Noctua NH-D14 // Crucial M4 64GB // Samsung F3 1TB
WD Caviar Black 2TB // Corsair AX750
Beyerdynamic DT880 Pro 250Ω // Schiit Modi+Magni
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
