Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #11
Old 12-04-05, 09:28 AM
enVias enVias is offline
OC3D Elite
Originally Posted by name='kempez815'
Yeah and if you carry you PC around then there is always the worry about putting the wait on the CPU.
Don't want to keep people weighting because of all the wait you have to carry around
__________________
  #12
Old 12-04-05, 09:34 AM
FarFarAway FarFarAway is offline
Newbie
Leave me alone - I'm ill!
Duly corrected.
  #13
Old 12-04-05, 09:35 AM
OC3D Elite
Duly corrected.
haha, it's ok.
we all make mistaiks
__________________
  #14
Old 12-04-05, 11:57 AM
FragTek's Avatar
FragTek FragTek is offline
OC3D Elite
Send a message via AIM to FragTek Send a message via MSN to FragTek Send a message via Yahoo to FragTek
Originally Posted by Austin
haha, it's ok.
rofl
__________________
AMD FX-8370 @ 4.7Ghz | Asus Sabertooth 990FX R2.0 | 32Gb G.Skill Sniper DDR3-1866 | XFX Radeon R9 390X
Samsung 850 EVO 500Gb SSD / OCZ Vertex 4 128Gb SSD / 2Tb WD Black / 3 x 2Tb WD Green
PCP&C Silencer 750w | Fractal Design R3
  #15
Old 17-04-05, 02:27 AM
anval anval is offline
Newbie
I just wanted to make a comment on copper vs. aluminum
Heat capacity: aluminum VS. copper
In addition to surface area and the air flow through the heat sink, the material which the heatsink is made of is even more influential in cooling. For instance, different materials have different heat capacities. The heat capacity of a material indicates the amount of heat energy (measured commonly in joules or calories) a certain type of material with a certain mass can receive before it's temperature goes up by a specific amount. The heat capacity of aluminum is measured to be 900J/kg*K, which means that for a 0.25Kg block of aluminum it will take about 1125 Joules of energy to have it's temperature raised by 5 degrees. The temperature of a 0.25Kg block of copper, which is measured to have a heat capacity of 386J/Kg*K, will rise by 5 degrees with only 483 Joules of heat energy. What the heck does that mean? Simply it means that copper will rise in temperature more than aluminum when the same amount of heat is applied. Does this mean that aluminum is a better cooling material than copper? Not necessarily, because there is a more important factor to consider: thermal conductivity.
Thermal conductivity: aluminum VS. copper -
Thermal conductivity, as it obviously implies, is a measure of how well a type of material can conduct heat. A higher thermal conductivity means a better conductor of heat. Copper has almost twice the thermal conductivity of aluminum (401 W/m*k compared to 237 W/m*k), which makes it a clear choice over aluminum for CPU cooling as it can transfer high amounts of heat more efficiently. The main reason for comparing aluminum and copper is because most older HSF products use aluminum for the heatsink, while recently the trend in cooling products is to use copper instead.
  #16
Old 17-04-05, 01:42 PM
FragTek's Avatar
OC3D Elite
And another little clarification for anyone who doesnt know... The XP-90/120 have copper bases, they're just nickel plated to look blingtastic
__________________
  #17
Old 17-04-05, 02:32 PM
Newbie
Eeeeexcellent....was thinking that they didn't....now I'm deffo glad I got one coming!!
  #18
Old 17-04-05, 03:08 PM
FragTek's Avatar
OC3D Elite
Most people don't know that
__________________
  #19
Old 17-04-05, 07:19 PM
|3ourne |3ourne is offline
OC3D Crew
It just basically means that between an XP90 and an XP90C , XP90C needs a higher cfm fan to get rid of the heat since copper can hold less heat than aluminum. XP90 , you can use a slower silent fan and still get away with it , but XP90C actually outperforms an XP120 when its coupled with a nice beefy delta or Panaflo becoz copper than dissipate heat faster.
__________________
Intel C2D E6750 @ 3.6 ghz { 1.375 V }
MSI P35 Platinum { Hate it }
Crucial Ballistix Tracers @ 1100 mhz 5-5-5-15
Powercolor HD3870 + Thermalright Cooler { Hate it }
Razer Barracuda AC1
Ocz Powerstream 520 Watts { I cannot believe its still alive }
Thermalright Ultima 90 { Lapped }
LOTS OF FANS !!!!!!!!
  #20
Old 17-04-05, 07:31 PM
FragTek's Avatar
OC3D Elite
Beefy Delta = OSHA thinks you should wear hearing protection while in the same room, lol.
I'll go with the XP-120 and slower fan thanks
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
