Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #1
Old 15-03-05, 12:44 PM
Aman Aman is offline
Newbie
NV Silencer 5 dropped temps and noise
For my geforce 6800 card i opted to go with aftermarket cooling because under load the stock cooler sounded like a helicopter. Stock kept temps around 58degrees celcius gpu and 38 ambient temperature; with stock cooling and overclocking on the gpu i was able to hit over 90 degrees celcius on the gpu, now thats too hot for comfort even though the limit is 127 degrees celcius (27 degrees hotter than boiling water). I slapped on a Artic Cooling NV Silencer 5 for 6800 gpus with the provided generic white paste and it dropped my temps to 48 degrees idle on the gpu and never over 60 on load and most importantly its silent.
  #2
Old 15-03-05, 09:17 PM
FarFarAway FarFarAway is offline
Newbie
Yeah I'mthinking about going with a NV5 - there good coolers. Seeing as I've already voided the BFG lifetime warranty on my vid card my soft OC'ing it - I might as well!
  #3
Old 15-03-05, 10:20 PM
mikechandler mikechandler is offline
Newbie
Yeah i have the NV Cooler too, it keeps heat reduced and pumps out hot air through vent at back as per the dual slot solutions, only problem is its a tight fit in an asus a8n sli deluxe as the northbridge fan is about 2mm away from the cooler.
  #4
Old 15-03-05, 11:33 PM
vice vice is offline
Advanced Member
These are excellent long lasting cheap awesome solutions to nvidia's cement grinder stock fanstfor $25-35 US. I'd recommend it to anyone that needs a replacement.
  #5
Old 16-03-05, 08:06 AM
PV5150 PV5150 is offline
OC3D Elite
I have heard that the NV5 is quite an effective cooler, and very quiet. They are a bit large for my taste, and peeps used to complain that the Nvidia reference heatsinks on the GF 5800 and 5950 were large There are plenty of other VGA cooling options available from Vantec, Zalman....just to name a couple.
Wow, thats really hot for a vanilla 6800, what are your case temps??? I have a 6800GT and oc'ed, mine has never even gotten anywhere near that!!!! The temps you gave after the NV5 mod, idle-48 deg C and load-60 deg C...my GT idles 2 deg lower than yours and after gaming has only reached 58 deg C. I would be checking my positive case pressure, to ensure sufficient cooling of your total system as a word of advice also. Good Luck
PV
__________________
Originally Posted by name='Jim'
"Jonathan 'Fatal1ty' Wendel may be 12-time world gaming champ, but how does he cope inside a 50c hot box sucking on a heavy load?":rocker::rocker:
  #6
Old 17-03-05, 09:56 PM
NickS NickS is offline
OC3D Elite
Yeh know, you really don't screw yer warranty over by oc/ing or unlocking pipes. as long as you lock the pipes & shader and put it @ stock when you send it back they never know
__________________
Laptop
Sony VAIO CS110E 14.1" :: Core 2 Duo T5800
3GB DDR2-800 :: 250GB HDD :: Intel Media Accelerator
HTPC
Gateway GT4024 :: Intel Pentium D 805 :: 1GB DDR2-667
700GB of Storage :: ATi Xpess200 :: Sharp AQUOS 32" 720p
  #7
Old 17-03-05, 10:05 PM
CrArC CrArC is offline
Member
Sometime they'll end up thinking of logs stored in a tiny EEPROM... what could be worse...
They say big fans at low RPM get better cooling and reduced noise levels, is it possible to fashion a sick form of heatsink from a large 110mm casefan, duct tape and bits of plastic?
__________________
-- λ˛ --
  #8
Old 18-03-05, 09:25 PM
gmac42 gmac42 is offline
Newbie
yeah really me two except
i put the same thing on my 6800 and it went really silent except for my star ice 775 cooler i click on oc guru and work my 3.8 to 3.975 mhz and my fan goes like a turbine engine and counters all the nice quiet coolers on my sys..........
  #9
Old 19-03-05, 08:14 AM
balilu balilu is offline
OC3D Crew
i currently have the stock cooler which is quite gr8 but iv removed the stock fans and installed a vantec spectrum pci card cooler and reduced temps about 2 degrees idll and 5 degrees load and it currently runs 47 degrees idle and 65 degrees load.
and it looks very gr8.
btw my 6800gt is working at Ultra Speeds
  #10
Old 19-03-05, 05:20 PM
Joe Joe is offline
OC3D Elite
yea i use one of their ati silencers which allowed me to oc by bout 25%
HINT: use Arctic Silver 5 instaed of the they give u cause it will eventually (after it 'cures' - this takes bout 200 hrs of off/on usage) give u about and extra 15MHZ (it did in my case)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
