Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #21
Old 24-02-14, 03:47 PM
MadShadow MadShadow is offline
OC3D Elite
I can just feel SuB's anger rising while reading this tread... Mallarmist, you pulled off a triple post!
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #22
Old 24-02-14, 03:52 PM
mallarmist mallarmist is offline
Newbie
i read that a dead cpu, makes no beeps nor it gives signal on monitor :O can a cpu break if i used wrong cable to cpu power?
  #23
Old 24-02-14, 04:12 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
CPU Power connectors are either a single 4pin [email protected] or the (4+4) 8pin [email protected]
PCIe Power connectors
The 6 pin PCI-E cable has 3 12V lines (yellow) and 3 ground return lines
8 pin PCI-E cables have 3 12V lines and 5 ground return lines
6 pin being 75W and the 8 pin being 150W.
These cables should NEVER be mixed up.
You have possibly bummed your motherboard or your GPU, either way it's RMA time.
This just cracked me up the unholy grail of tripple posting.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #24
Old 24-02-14, 05:04 PM
Newbie
well, i know my graphic card works, my psu my new ram :O but i dont know about the motherboard or cpu is there anyway to find out if a cpu is dead?
  #25
Old 24-02-14, 05:13 PM
Wraith's Avatar
Bettyswollocks
Put it in a working motherboard other than that there's no other way to check.
__________________
  #26
Old 24-02-14, 05:40 PM
TheOuterOne's Avatar
TheOuterOne TheOuterOne is offline
Advanced Member
Wouldn't that risk damaging the working motherboard?
__________________
THEOUTERBOX V1
AMD Sempron 2800+
  #27
Old 24-02-14, 05:53 PM
Newbie
well, i got the sulution :P i'm buying a new motherboard and i hope it works orelse i have to buy a new cpu too ... damnit i hope not because i bougth a upgrading package for my computer a week ago and i dont have warranty
poor wallet
Tags
motherboard, ram
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
