Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #10041
Old 04-06-19, 09:00 PM
AMD Enthusiast
Originally Posted by looz View Post
Getting a bit fed up with just Linux again, so ordered a SSD for dual booting:
1TB nVME for 115€, though it's QLC so not exactly the performance or longetivity king.
I kinda have the same feeling with Linux too.
You might remember I tried using Linux Mint a while ago and I didn't really like it and switched to Zorin and liked it more. But as I'm not a Linux guru it's a massive learning curve so I can only use it for so long until I just use my windows PC
__________________
I am Iron Man.
  #10042
Old 05-06-19, 04:38 AM
looz's Avatar
looz looz is online now
OC3D Elite
Yeah I keep rotating between single boot Windows and single boot Linux since both annoy me in different ways, but my current 512+512 setup is a bit cramped for that.
But to learn linux I'd actually recommend jumping into deep end and installing Arch, that way you choose most major components individually and get a picture of what components a complete system includes and how they interact.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #10043
Old 05-06-19, 05:56 AM
AMD Enthusiast
Probably a smart way to do it I just don't have enough time to do that. I have anywhere from 40-60 hours of school a week. Not enough time to really do anything else anymore for the next roughly 6 months
__________________
I am Iron Man.
  #10044
Old 05-06-19, 12:37 PM
looz's Avatar
OC3D Elite
Made my case look like a complete kludge by moving the rad to top with fans outside since they don't fit inside. This allowed me to put two newly bought fans in the front and as a result GPU now has decent supply of fresh air.
For part two in improving my case's airflow I ordered a Meshify C front panel which doesn't impede airflow nearly as much. Judging by images it *should* be a drop-in replacement as long as I remove the power button assembly but we'll see how that goes.
__________________
  #10045
Old 05-06-19, 01:01 PM
tgrech tgrech is online now
OC3D Elite
When it comes to ugly airflow improvements I think you're pretty safe, ended up using power tack to attach that fan in a way that would dampen vibrations without requiring cuts to the metal (Clips were kinda noisy no matter what I softened them with).
The 3.5" controller that has to hang out the back due to my motherboards lack of 3-pin fan headers doesn't do it any favours either.
It's mostly a gaming PC though with a secondary use as a deployment PC for any heavy long workloads (Mostly compilation) I don't want my ThinkPad getting dogged down with so it has to be pretty quiet with its location. (The window was already smashed)
  #10046
Old 05-06-19, 01:14 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
You needed one of these lol.
IIRC it had a 320mm fan in it.
__________________
"Those really high 20 series prices are just place holders"
  #10047
Old 05-06-19, 01:49 PM
looz's Avatar
OC3D Elite
That dampening is brilliant though!
__________________
  #10048
Old 05-06-19, 02:34 PM
Damien c Damien c is offline
OC3D Elite
Take the image of the case with the large fan mounted to the side of it, and then replace that fan with 2 large desk fans, and that would be the image of what one I my pc's use to look like.
It was all caused by a hot south bridge chip and the gap between 2 GPU's being to small thanks to Asus not spacing them correctly, I cannot remember which board it was but I know it was an Asus LGA775 board.
__________________
  #10049
Old 05-06-19, 02:43 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Was it the P5N nvidia chipset based boards, because i used to have one of those and with 2 8800gtx cards managed to prettymuch fry the south bridge and the sata controller ate it xD
  #10050
Old 05-06-19, 03:08 PM
AMD Enthusiast
I remember when massive side fans were a thing
We needed it then bad. GTX 480 days.. lol
__________________
I am Iron Man.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
