Thread Tools Display Modes
  #21
Old 23-10-15, 02:32 PM
Craigferrie's Avatar
Craigferrie Craigferrie is offline
Member
duel loops are fun, but as you said it can get hectic.
On the other hand, the case is pretty open and spacious.
just to confuse you more lol
__________________
  #22
Old 23-10-15, 02:35 PM
Permafrost's Avatar
Permafrost Permafrost is offline
Compo Whore
Originally Posted by Craigferrie View Post
dual loops are fun, but as you said it can get hectic.
i was thinking the same but i really want forum members input.
__________________
  #23
Old 23-10-15, 02:48 PM
tinytomlogan's Avatar
The Guvnor
Originally Posted by Permafrost View Post
so let's back on topic, so I am considering a dual loop with two 10w ddc's stacked at the front, do you guys think it'll look busy or messy? or would it be best for a single D5 with a 250ml top? thoughts and opinions guys and girls?
I think it will be way too messy and not required. A single series loop will be MUCH tidier and quieter. DDC's are a b.tard to get quiet.
I personally use a single D5 in Orca and its on setting 2 - you dont need a mega pump set up very often
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #24
Old 23-10-15, 02:58 PM
Permafrost's Avatar
Compo Whore
I personally use a single D5 in Orca and its on setting 2 - you don't need a mega pump set up very often
tbh the 10w ddc i for in the ek ddc heatsink is pretty quiet, by the sound of things it's going to be a D5.
does anyone here have an exp on the XSPC photon 270 D5?
EDIT: thanks for your input guys keep 'em coming
__________________
  #25
Old 23-10-15, 03:35 PM
Asperatis's Avatar
Asperatis Asperatis is offline
Advanced Member
A single d5 will be plenty indeed. I'm running cpu, 2 gpu and 2 460 60mm rads on one EK d5 pump which is set to speed 2/5. Nice and quiet and plenty of flow too Double loops look nice, but it's more something you should do in huge cases such as a Caselabs SMA8 imho
__________________
~Nyssa~
900D - Rampage V Extreme - 5930K - 32GB Corsair 2666 DDR4 - Titan X SLI - Xonar Phoebus - AX860i - Samsung 950 Pro 512GB - Samsung 850 PRO 256GB - 1x 2TB WD Red - Custom Acrylic Loop
Build Log
  #26
Old 23-10-15, 03:37 PM
Permafrost's Avatar
Compo Whore
yeah i've been looking at your build log, i really, really like that ras you got
__________________
  #27
Old 23-10-15, 03:43 PM
Asperatis's Avatar
Advanced Member
Thx had to order it from ppcs though as I couldn't find it in Europe. It comes with a uv cathode too should you wish to light it up.
__________________
~Nyssa~
Build Log
  #28
Old 23-10-15, 03:47 PM
Permafrost's Avatar
Compo Whore
i heard they stopped making them, if you sell it let me know :P
__________________
  #29
Old 23-10-15, 04:21 PM
Asperatis's Avatar
Advanced Member
You should verify that with FrozenQ, as I'm not selling mine
__________________
~Nyssa~
Build Log
  #30
Old 26-10-15, 12:10 PM
Permafrost's Avatar
Compo Whore
just a little update:
i was at mcm expo on the weekend so i couldn't get much done so a friend popped over to give me a hand who is a twitch streamer by the name of Baz_Wilson
the cpu block in on the board
and now the the gpus are blocked up and installed
today i'll be trying my hand at acrylic bending for the first time, any pro tips from forum member?
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
