Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat > Humour
Thread Tools Display Modes
  #11
Old 27-06-17, 08:35 PM
joey117 joey117 is offline
OC3D Crew
Ok I think this has been taken out of perspective the power supply that is on top of the computer has being powering the computer for a grand total of one two minutes tops it is also had a watt metre attached to a wall so it doesn't over draw Watts and amps and it only turned on long enough to make it to Windows check that was all the RAM was being showning and check the graphics card was being detected correctly after that I took a picture and shut the computer down after that it has not been on whatsoever . I think people of talking this like I'm using this as a daily driver I really am not
Sorry for the bad English I am dyslexic I am using my phone speak and write function to make this the picture was meant for humour only and I think it's got out of hand
  #12
Old 28-06-17, 01:08 AM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
No need to explain fella it's all cool, we're just concerned for you and your RIG. So which PSU are you getting next?
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #13
Old 28-06-17, 10:38 AM
OC3D Crew
If I can get warranty replace my old power supply unit there will be a 1500 watt Corsair AXi power supply going into the computer if I cannot get them to replace it it's going to be a 1200w or if they do it a thousand watt cosrair unit save stripping all the wiring out of the computer
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
