Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #11
Old 06-06-19, 01:28 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
As a direct comparison here is my now old 1600
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #12
Old 07-06-19, 11:59 PM
epiqpwnage epiqpwnage is offline
Newbie
You won't go in depth because you don't really understand it. Lol. Just like linus. Sure he created linux. But it seems he stopped evolving and can't keep up with the times.
And he said that years ago about geekbench3. Don't be a sheep that blindly follows and spouts the same unfounded claims just so you would look smart on the interwebz
By your linux having a better gb score than your windows score just means linux used the hardware better or it has better performance/programming/interpreter than windows. Cross platform means it can run on multiple os without changes to its code...just like java.
Just as long as it is not programmed for a specific brand then it should be no problem.
Originally Posted by Gothmoth View Post
only problem is that geekbench is pretty useless.
not going into depth here but linus torwald and others wrote about it.
you can find it on reddit.
only one thing.. geekbench is meant as cross platform benchmark.
yet my TR has double the performance under linux (compared to windows).
most of the test are said to fit into the L3 cache.
there is so much wrong about geekbench i would not even know where to start.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
