Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
Thread Tools Display Modes
  #1
Old 24-01-15, 10:01 AM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
My Build With Modified Swiftech H240-X
Alright here's my rig which I've been working on quite some time. I first tried with an EK-Kit set, but the pump was so noisy it made me crazy. I also had a Corsair Obsidian 750D case at first, however there was so much wrong with this case even though I really liked the design. The build quality was pathetic to say the least.
My main goal with this build was to get a reasonable silent PC for gaming, which is why I went for the Fractal Define R4. I had to mod the plastic front so the H240-X would fit, but it wasn't too much of a problem. Guess I couldn't be arsed to buy the new R5
I don't typically care much about overclocking except on the GPU. So this system wasn't built for heavy OC, hence why I only have one 280mm radiator. My temps are quite decent considering. And the Matrix 780 Ti gets HOT with its default cooler attached... I was always hitting 83 degrees at full load.
Load Temps:
CPU: max 55 degrees Celsius.
GPU: max 62 degrees Celsius.
Specs:
Fractal Design Define R4 Black Pearl
Intel i7 5820K @ 3.6 GHz
G.Skill Ripjaws 4 2666 MHz CL15, 4x4 GB
ASUS X99-A
ASUS Matrix Platinum GTX 780 Ti 3 GB (1092 MHz Boost Clock)
Samsung SSD 850 Pro 128 GB
Samsung SSD 840 Pro 512 GB
Corsair HXi 1000w
Swiftech H240-X with Noctua NF-A14 fans
EK EK-FC780 GTX Ti Matrix - Acetal+Nickel w/ backplate
Silverstone AP141-UV + Corsair AF140 Quiet Edition fans
CableMod cables for PSU
Notes: I know the PSU is overkill, but I couldn't get the other models back in September. The red RAM isn't intended either, but again back in September there was a serious lack of DDR4 memory on the market. I don't use a windowed side panel anyway, so no big deal.
Also sorry for some of the pictures being slightly blurred. It seems I don't have a very steady hand.
Click image for larger version
ID:	9375   Click image for larger version
ID:	9376   Click image for larger version
ID:	9378   Click image for larger version
  #2
Old 05-02-15, 02:48 PM
joca94 joca94 is offline
Member
Cool rig, btw am i seeing an optical drive in there?
  #3
Old 05-02-15, 03:35 PM
Gripen90's Avatar
Gripen90 Gripen90 is offline
Newbie
Great rig, looks really nice
__________________
  #4
Old 06-02-15, 06:40 AM
tolagarf's Avatar
OC3D Crew
Haha indeed
Still need that once in a while.
  #5
Old 06-02-15, 08:07 AM
Warchild Warchild is offline
OC3D Elite
What is an optical drive? mwahaha
  #6
Old 06-02-15, 08:39 AM
Gripen90's Avatar
Newbie
The one you need for your Motherboard installation DVD to get the LAN drivers installed so you can go online and make the DVD-Rom superfluous
__________________
  #7
Old 06-02-15, 09:31 AM
OC3D Elite
Windows should have default network drivers for that now
  #8
Old 06-02-15, 09:34 AM
Gripen90's Avatar
Newbie
Hehe yea but unfortunately not everytime that works
Sorry for the OT OP... went a little of track here
__________________
  #9
Old 06-02-15, 10:11 AM
tolagarf's Avatar
OC3D Crew
Np
No that's not actually the reason for it being there. I have some old games and stuff on DVD/CD that I'd like access to, as well DVD movies. I don't have a dedicated DVD player.
  #10
Old 09-02-15, 03:51 PM
The_Governour's Avatar
The_Governour The_Governour is offline
OC3D Crew
looks nice and clean! some nice temps with only a 280 rad.
Tags
h240-x, swiftech, water cooled, x99
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
