Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #161
Old 06-02-14, 12:59 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Did this board ever end up being good with a newer bios or still industry worst price to performance ratio ?
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
Battle.Net: Dicehunter#2746
  #162
Old 06-02-14, 01:04 PM
tinytomlogan's Avatar
The Guvnor
Its 'as good' as the others once they sorted the bios matey yes. They had been making ones for me to try and fix an issue and after the 4th one I just got fed up with testing!!!
After a few weeks and lots of rows they realised they had borked it their end!
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #163
Old 06-02-14, 01:31 PM
Dicehunter's Avatar
Resident Newb
Cooleo thanks for the reply, For a straight up gaming rig, 2-way 780 TI SLI, 4770K, Which would you suggest, This or the Formula ?
*EDIT*
Scratch the last question, Just watched the Formula review, Purchased the Formula
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
  #164
Old 06-02-14, 05:38 PM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
*EDIT*
What's wrong with your Sabertooth??
Getting worried about you dude, that upgrade bug is really consuming you.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | GTX 1070 | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
  #165
Old 06-02-14, 06:28 PM
Dicehunter's Avatar
Resident Newb
Donating it to a family members gaming rig
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
  #166
Old 06-02-14, 06:32 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Well that's going to mess up your colour scheme...
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #167
Old 06-02-14, 06:36 PM
Dicehunter's Avatar
Resident Newb
I thought so too but it strangely goes together, The red from the sound card, NIC, H100i and then the board with the sorrounding colour being a green glow, Sounds odd I know but it works
__________________
Steam: Dicehunter
Origin: Dicehunter
Uplay: Dicehunter
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
