Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #121
Old 18-07-08, 04:40 PM
markkleb markkleb is offline
OC3D Elite
well Mraopc my thought is if there is room the bigger rad is best. A dual may work but a triple adds extra cooling.
As to the res my thought is anything that adds splashing or any chance to whip air into the fluid is bad, so I try to stay as far away from them as possible.
__________________
Thanks
  #122
Old 18-07-08, 06:57 PM
mrapoc mrapoc is offline
OC3D Elite
ok so well go for the room for triple rad and primarily not designed for a res
__________________
  #123
Old 18-07-08, 11:00 PM
Toxcity Toxcity is offline
OC3D Elite
A res can be positioned almost anywhere.
I was aiming for an outside res.. but I am sure I can figure a way to do that.
__________________
Main System: Intel i5 2500K @ 4.8Ghz, 8GB Corsair Vengeance 1866Mhz, Geforce GTX 560 Ti
  #124
Old 19-07-08, 10:10 PM
nunzio nunzio is offline
OC3D Crew
Never thought of outside the case.. Sweet idea.
  #125
Old 20-07-08, 02:49 AM
OC3D Elite
well I keep saying you dont need one and you guys keep figuring ways to add one
Il figure a way to put one in the case, remember it should be at the highest point in the loop.
__________________
Thanks
  #126
Old 20-07-08, 01:02 PM
OC3D Elite
i only used 1 b4 as kemp included it
cant really be arsed with one tho if its extra work and money =/
__________________
  #127
Old 22-07-08, 12:27 AM
OC3D Elite
The extra work is no prob for you 3 guys. Extra money is also un needed, to me the only issue is if it is a benefit to the case/comp.
If it is just added stuff than its silly but if it does serve a purpose I am happy to include/make one.
Check with other H20 Gurus and see if they say there is a benefit to the res.
__________________
Thanks
  #128
Old 22-07-08, 08:42 AM
OC3D Crew
I've got mixed feedback about useing a t-line or a res.
TBH, I don't mind either way.
  #129
Old 27-07-08, 05:57 PM
OC3D Elite
I am really busy building the 3 cases for Nvision, but I will take a look in the next couple days how I would use a res for the comp.
Have you seen the ones from Koolance?
http://www.koolance.com/water-coolin...product_id=651
they look like a much improved DD version with more hose options.
__________________
Thanks
  #130
Old 27-07-08, 06:04 PM
OC3D Elite
I love that res mark!
Do we have an ETA on the cases? I am not being impatient just asking when we are to expect them.
Cheers.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
