Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 23-11-18, 10:51 PM
Yeungster Yeungster is offline
OC3D Crew
Corsair Hydro AM4 Retention Bracket
Hi - I'm not sure whether you are still producing or selling these?
I was sure you had some available earlier today in your Corsair store but it's showing as out of stock now.
Just ordered a new AM4 build and wanted to reuse one of my existing hydro coolers (H110i GTX or H100i v2) but neither have the correct bracket.
Any idea when these are back in stock in the UK Corsair store? None of the resellers you've listed have any left as they're marked as end of life.
Thanks
  #2
Old 23-11-18, 10:54 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
H110i looks like it has an Asetek pump.
https://www.overclockers.co.uk/asete...hs-04d-as.html
In which case you need that.
__________________
  #3
Old 23-11-18, 11:00 PM
OC3D Crew
Thanks for the quick response.
Can you believe my luck? Went back on the Corsair website and it's listed as back in stock, so all sorted now
  #4
Old 23-11-18, 11:02 PM
AlienALX's Avatar
OC3D Elite
No worries man. It should just be Asetek for both, so if you need another one then OCUK one I linked to should work
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
