Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 07-12-18, 04:44 AM
Nazyaweh Nazyaweh is offline
Newbie
H 150i PRO Push Pull
Can I get fan splitters to run 2 fans on each fan connector on the H150i Pro RGB cooler or will it not power them? I am currently running a H100i and it natively supports push pull and I want to use the same config with my new H150i Pro.
  #2
Old 07-12-18, 08:45 AM
Warchild Warchild is offline
OC3D Elite
I believe as long as the total draw on the fan header doesnt exceed 1amp at 12v, you are ok to put 2 fans on each. I have put 4-6 fans on a header in the past without issue, but then mine were always set to low RPM. Check the fan rating but I think you will be ok.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
