Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #11
Old 31-10-18, 04:09 PM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Originally Posted by AlienALX View Post
Does the PSU start with the paper clip method? you sure the tester isn't dodgy?
It does start now connected to a motherboard. It might have tripped earlier due to my CPU being a <insert nasty word here> , after I switched the CPU it seems to work. But the PSU tester is still beeping away even with only with 24 pin cable connected, which typically indicates there is some kind of issue. Corsair rep is looking into it atm.
  #12
Old 31-10-18, 04:16 PM
tinytomlogan's Avatar
The Guvnor
OK dude lets see what they say
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #13
Old 01-11-18, 09:04 PM
jonnyGURU jonnyGURU is offline
Newbie
Send a message via ICQ to jonnyGURU Send a message via AIM to jonnyGURU Send a message via MSN to jonnyGURU Send a message via Yahoo to jonnyGURU
Usually those testers beep when it's missing a voltage reading, but you're showing voltages on all the rails, so that's odd.
So the PSU is working now?
  #14
Old 01-11-18, 09:39 PM
tolagarf's Avatar
OC3D Crew
Yes last couple of tests it was working fine. My RMA has been accepted and at this point I'm unsure if I should ship it or not
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
