Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #21
Old 04-07-17, 03:55 PM
Kaapstad's Avatar
Kaapstad Kaapstad is online now
OC3D Elite
Originally Posted by AngryGoldfish View Post
A lot of people here did not expect the 1080Ti to beat the Titan XP. The reviews came out and people were not necessarily shocked, but they doubted Nvidia would match the Titan.
1080 Ti does not beat an old Pascal Titan or the newer Titan Xp.
I own all the above cards.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #22
Old 04-07-17, 04:05 PM
AngryGoldfish's Avatar
AngryGoldfish AngryGoldfish is offline
Old N Gold
You don't need to own a GPU to be able to have a solid idea of its performance. Otherwise this site would likely not exist, not in its current form.
The 1080Ti is within a small margin of the Titan XP, and with factory overclocks from AIB partners the 1080Ti is as fast as or beats the original Titan XP. If your findings are different, that's fine, but that's not the findings I go by.
Originally Posted by The F34R Channel View Post
They've pretty much done so with each Ti so we should continue to expect it.
Maybe they should, yes, but the Titan XP was such an expensive powerhouse when it came out that some did not expect even Nvidia would match or beat it with the 1080Ti.
__________________
ASUS X370 Crosshair VI Hero ⁞⁞ Ryzen 1600X 4Ghz ⁞⁞ Thermalright Le Grand Macho RT ⁞⁞ Aorus GTX 1080 11Gbps ⁞⁞ G.Skill TridentZ 3200Mhz
Jonsbo W2 ⁞⁞ Corsair AX760 ⁞⁞ Pexon PC ⁞⁞ Samsung 960 EVO 250GB & 850 EVO 500GB
⁞⁞ Western Digital 1TB Blue & 3TB Green
BenQ XL2730Z ⁞⁞ Mixonix Naos 7000 ⁞⁞ Corsair K70 Cherry MX Brown ⁞⁞ Audio-GD NFB-15 ⁞⁞ EVE SC205 ⁞⁞ AKG K7XX
  #23
Old 04-07-17, 04:24 PM
TheF34RChannel's Avatar
TheF34RChannel TheF34RChannel is offline
OC3D Elite
You're right that it's more of a match rather than beating it, I shouldn't have claimed that.
  #24
Old 05-07-17, 07:07 AM
MiNo MiNo is offline
Member
I'd love to see two "x/y" graphs for all the 1080ti
1: average FPS in games pr card
2: FPS/price
  #25
Old 05-07-17, 07:09 AM
Kaapstad's Avatar
OC3D Elite
It is not just my results that I go by. I keep score of a large number of results on another forum and the Titan old and new consistently beats out the 1080 ti.
Having said that if we are talking value for money in a gaming context then I would recommend the 1080 Ti every time.
__________________
#041
  #26
Old 05-07-17, 09:12 AM
Cbotha15 Cbotha15 is offline
Newbie
Damn 40fps for GR: Wildlands at 4k. That game murders just about any gpu you can through at it!
__________________
Intel Core i5 4690K @ 4.5Ghz, MSI Z97 Gaming 7 Motherboard, 16GB DDR3 Corsair LP RAM, EVGA GTX 1070SC, Corsair Ax860 PSU, Cougar Panzer Mid Tower, Corsair H100i GTX Cooler, Corsair ML120 Pro LED Case Fans, Crucial MX300 1TB SSD, Seagate 2TB HDD
  #27
Old 05-07-17, 01:23 PM
Old N Gold
I thought maybe you'd post some findings proving your point since you disagreed with mine, which is backed up by data spread across the Internet freely available to quote. I need to see what your results are, otherwise I can only go by tech websites. Example:
The second website I went to was Guru3D (I first visited TPU but they did not have Titan XP benchmarks listed in the way I needed), and The Witcher III was the first benchmark I clicked on. The 1080Ti FE beats the Titan XP. However, the Titan XP is obviously using older drivers which might explain the performance you are referring to. But I have that partially explained.
As you can see below, the Titan XP hasn't increased in performance in the six months between when the Titan XP and when the 1080Ti (and more specifically the MSI Lightning 1080Ti) were benched. Likely because it's not been tested again and the numbers are being reused. I hate that but that's not much anyone could do about it.
(Recent drivers)
(Older drivers)
But drivers for the 1080 haven't improved performance by a considerable amount as shown below so why would the Titan XP? Note the boost clock of the FE 1080 in the below image.
Now note the boost clock of the Aorus 1080 that was reviewed last month. It's considerably higher. It also has a substantial memory overclock from the factory.
Now note the score in Rise of the Tomb Raider for the original FE 1080 review and the more recent Aorus 1080 review with recent driver updates. It goes from 100 FPS to 110. That performance benefit can mostly be attributed to the 140Mhz additional boost the Aorus achieves over the FE 1080 and the 11Gbps memory overclock from the factory. Only a small amount can be attributed to drivers. This suggests drivers have not improved performance dramatically for Pascal. It has only been marginal in a game like RotTR.
My point is, while this is not definitive information, it's all I have to go by. I can't afford to buy every fancy new graphics card that comes out. According to the findings of Guru3D (again, second site I went to, first benchmark I clicked on), the 1080Ti is within margin of error of the Titan XP. You corrected me by saying, "1080 Ti does not beat an old Pascal Titan or the newer Titan Xp." But according to the only results I have available to me (without scouring OCN or other forums), the 1080Ti DOES beat the Titan XP, and that's without the AIB partner factory overclocks, or more specifically GPU Boost 3.0 overclocks.
But really does it matter? Why did you even bother correcting me since the point was not that the 1080Ti BEAT the Titan XP but that it came within such a close margin and regularly stood strong against it that it shocked a lot of gamers. That's the point. Correcting me just seemed pedantic, or maybe an attempt to prove your worth when you've given me no reason to trust you over anyone else. That isn't meant to offend. I'm pointing out what I've said about others. Don't just tell me how I'm wrong when I'm not an idiot. I don't just pluck numbers from my a**hole. There is data there. If you have different data that disproves it, prove it.
__________________
  #28
Old 05-07-17, 02:30 PM
Kaapstad's Avatar
OC3D Elite
You really should not believe all you read on some of these review sites.
Here is my little air cooled Titan Xp running stock volts, stock bios and quite old drivers.
https://forums.overclockers.co.uk/posts/29782421/
Lots of the other cards in the table are water cooled, overvolted or even use custom bios.
My score was the first one I got without any real effort.
People who know me on this forum know I could post loads of more links showing how well the Titan Xp perform. They win every time in bench threads against the 1080 Ti so much so that it is boring and pointless to use them.
The downside for the Titan Xp is they are not good value for money and in a gaming context people are going to get better VFM with a 1080 Ti.
__________________
#041
  #29
Old 05-07-17, 02:36 PM
Old N Gold
I wasn't talking about the Titan Xp (little 'p'), I was talking about Titan X Pascal. I know the Titan Xp (little 'p') is more powerful than the 1080Ti in both benchmarks and games. I always said Titan XP (big 'P'). And according to your results the 1080Ti and the Titan XP (original from August 2016) are roughly the same performance. That is my point.
I'm not going to stop paying attention to reviewers. They are just one piece of the puzzle.
__________________
  #30
Old 05-07-17, 02:45 PM
Kaapstad's Avatar
OC3D Elite
Check that link again, the old Titan XP also beats out the 1080 Ti consistently.
__________________
#041
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
