Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #31
Old 14-04-17, 07:18 AM
Vipermk2's Avatar
Vipermk2 Vipermk2 is offline
Newbie
I tried the update yesterday but rolled it back after an hour, 'DTS interactive sound' wasnt available as an option in the default format section or in 'Realtek HD audio Manager'
__________________
Rampage V Edition 10 - i7 5930k - 32Gb Corsair Dominator Platinum - Samsung 960 Pro 512 - Seasonic Prime 750w - Noctua NH-U14S - K70 RGB LUX - GTX 1080Ti Strix - Acer Predator XB321HK- Windows 10 Pro x64
  #32
Old 17-04-17, 02:38 PM
Greenback's Avatar
Greenback Greenback is online now
OC3D Elite
got this today from windows update, it pop'd up a msg showing my current privacy settings said they would be kept, after it installed it had turned 2 back on.
Also notice when I did the manual install it had the security option b4 booting in to windows, the auto update doesn't, doesn't even let you know that there are new privacy settings added
__________________
CASE: NZXT H440 white
CPU: RYZEN 1500x, H100i GTX
MB: MSI TOMAHAWK ARCTIC
RAM: 2x 8GB CORSAIR VENGENCE LED
GPU: TTL white 1060
OS: CRUCIAL MX100 250GB
PSU: Corsair Rm850x
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
