Thread Tools Display Modes
  #11
Old 28-04-17, 05:20 PM
ciobanulx's Avatar
ciobanulx ciobanulx is offline
Advanced Member
I don't think I've done this many water blocks on a motherboard before, and GPUs will be added as well of course :P
I'm excited to pipe it all up!
I decided not to use the monoblock cover that comes with this Bitspower kit and I'll connect everything separately. It will work better with the look I am going for.
Thanks for checking it out!
Cheers,
Alex
  #12
Old 01-05-17, 12:51 PM
ciobanulx's Avatar
Advanced Member
Hey guys,
Here's some further progress of the way I mounted the reservoir/s and also some close-ups of the combo. You can also get a better look at the new back panel and the cut out in the mid section.
You can see the vinyl design for the fans and if you saw earlier in the build log, I showed the new CM RGB fans... well I ended up changing these to the red LED JetFlos to make things easier with the cabling; the RGB fans were adding one extra cable per fan and I would only want to have them on red for this build anyway so I didn't make sense to add the extra cables.
Thanks for checking it out and stay tuned as I wrap up this build log.
Cheers,
Alex
  #13
Old 02-05-17, 09:36 AM
ciobanulx's Avatar
Advanced Member
Alright, motherboard is in, the reservoir is in, some of the tubes are in and the graphics cards have waterblocks on. I'm using reference 980s but hey it's not about the latest hardware with this build.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
  #14
Old 02-05-17, 11:14 AM
rigel023 rigel023 is offline
Newbie
beautiful case... but don't lose the keys. it would be a waste if its lost. ahaha
  #15
Old 03-05-17, 12:42 PM
ciobanulx's Avatar
Advanced Member
Hahaha that's true :P
  #16
Old 03-05-17, 12:47 PM
ciobanulx's Avatar
Advanced Member
Okay guys, the build is actually finished at this time however I haven't had time to take final photos yet so I will share the last update!
Thanks for checking it out and stay tuned for final photos!
Cheers,
Alex
  #17
Old 04-05-17, 10:48 AM
ciobanulx's Avatar
Advanced Member
Okay guys here we go, final photos!
Here is my Tempest, Mass Effect inspired build!
What I wanted out of this is a custom system that is very well put together and also engineered quite well, taking advantage of every single inch inside the Maker 5t chassis. That and a very nice and complex yet clean looking water cooling loop. The idea was that the build would look like a spaceship engine or a reactor of some sorts, something that would belong in the world of Mass Effect! I'm pretty happy with the finished result!
Huge thanks to the amazing companies that support me in achieving my dreams!
SPECS:
Case - Cooler Master MasterCase Maker 5t
CPU - Intel Core i7 6850K
MB - ASUS Rampage V Extreme
RAM - 4 x 4GB Kingston HyperX Predator 3000MHz DDR4
GPU - 2 x NVIDIA GeForce GTX 980
SSD - 2 x 240GB HyperX Savage
HDD - 2 x 2TB Seagate Firecuda
PSU - Cooler Master V1000
Fans - 8 x Cooler Master JetFlo - red LED
Custom cables & lighting - CableMod
Custom water cooling - Bitspower
Hope you guys like it
Cheers,
Alex
  #18
Old 04-05-17, 12:58 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Not usually a fan of busy looking buiilds, but this one I can look at for hours and see something new. Nice little touches in every corner and I'm starting to see the appeal of these master cases now. Kudos.
__________________
"As a species we evolved with complex communication and sound reasoning, monkeys fling poop." ~ Me
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #19
Old 04-05-17, 01:03 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Wow looks the mutts nuts really like what has been done to that case
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #20
Old 09-05-17, 04:06 PM
ciobanulx's Avatar
Advanced Member
Thanks a lot guys! Much appreciated
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
