Thread Tools Display Modes
  #1
Old 23-03-17, 08:37 AM
ciobanulx's Avatar
ciobanulx ciobanulx is offline
Advanced Member
Tempest (modded CM MasterCase Maker 5t) by SimpleModz
Hey guys,
Welcome back to another one of my builds logs! I'm happy to announce my entry into the 2017 Cooler Master CaseMod World Series in the MasterCase Maker 5t. It's a stunning looking case and I'm excited to work on it. I have a few interesting things planned for it, including some layout changes on the inside and a more unique water cooling loop set-up.
I am calling this one Tempest and it will be based on the Tempest spaceship from the new Mass Effect Andromeda game.
I did an overview video of the case as well as talked a bit about the mods where you can get a better idea of what I'm going to do in this case.
Check it out below:
SPECS:
Case - Cooler Master MasterCase Maker 5t
CPU - Intel TBC
MB - ASUS Rampage V Extreme
RAM - 8 x 4GB Crucial Ballistix Elite 3000MHz DDR4
GPU- NVIDIA TBC
SSD -2 x 275GB Crucial MX300
HDD - Seagate TBC
PSU - Cooler Master V1000
Custom cables & lighting - CableMod
Water Cooling - Bitspower
I'll start it off with some photos of the gorgeous case:
Thanks for checking it out and stay tuned for more
Cheers,
Alex
  #2
Old 23-03-17, 09:03 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Watching!
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=16gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #3
Old 23-03-17, 12:21 PM
Bartacus Bartacus is online now
OC3D Elite
Saw Tempest, got excited thinking it was a reference to the old table-top polygon game, but was disappoint!! I'll watch anyway, since OP goes great work.
__________________
Guts: Ryzen R7 1700 / Asus CH6 Hero / 16GB G.Skill 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Intel 600p 1TB NVME / 6TB RAID0 array / 2TB RAID0 array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #4
Old 23-03-17, 02:44 PM
Dawelio's Avatar
Dawelio Dawelio is offline
Previously Chrazey
New build one, nice!
Although I gotta say that it looks to be basically nothing new with every new release of these "Master" cases lol.
  #5
Old 24-03-17, 12:14 PM
ciobanulx's Avatar
Advanced Member
Originally Posted by Excalabur50 View Post
Watching!
Thanks mate
Hehe thanks mate
Thanks mate
I see it as Cooler Master continuing to improve on the case. It also makes it easier for people that purchased the initial model to upgrade things that have come out since, like the tempered glass side panels for example
  #6
Old 03-04-17, 12:24 PM
ciobanulx's Avatar
Advanced Member
Hey guys,
Progress has been slow with this one however I thought to give you guys at least some content as I'm still trying to figure out how to tackle this build
The case is fully stripped at the moment, ready to be cut into! And by the look of things, there will be a lot of cutting :P
Stay tuned!
Cheers,
Alex
  #7
Old 04-04-17, 02:01 PM
ciobanulx's Avatar
Advanced Member
Things have started to come apart :P
Stay tuned for more!
Cheers,
Alex
  #8
Old 09-04-17, 01:30 AM
ciobanulx's Avatar
Advanced Member
Not much real progress on the build with this update unfortunately. It's a bit hard to keep up with the 3 builds I'm working on at the moment.
Here are the new Cooler Master RGB fans.
Cheers,
Alex
  #9
Old 26-04-17, 01:58 PM
ciobanulx's Avatar
Advanced Member
Hey guys,
Sorry for the lack of updates on this build but unfortunately that's what happens when you're working on 3 case mods at the same time and they all have to be finished at the same time. Plus I've got my full time job on top of that. Been super busy lately.
What I'm gonna do however is focus on getting this build log ready and finishing this build as it has to be done and submitted for the Cooler Master Case Mod World Series by the 3rd of May.
So here is the progress that I've made so far. The PSU has been mounted in it's new location, I have a new motherboard tray that is mounted over the existing one to maintain the case rigidity, the back panel has been completely cut out and a new panel installed that has a 240 radiator mount and the I/O is in the top.
I also have the extra 'top' exterior panel mounted on the back. There is also a cut out in the mid-tray section with a piece of acrylic mounted over it. This is for the pass-through fittings later.
You will also see an acrylic panel in the bottom and a piece on the back.
I hope that all makes sense but I'll have a video in the end explaining it all and showing more of the actual progress for those interested.
I have to give a huge shout out to Corey from Imfaceroll Gaming for the help in cutting the aluminium panels on his CNC machine. Otherwise I don't know how I would have had time to get this done for the submission date.
Also thanks to Justin from Metalicacid for the tips on how to brush my aluminium panels. I think minus some of the deeper scratches they all came out really good. Most of that will be covered anyways.
So here are the photos guys!
I forgot to mention the cut out in the front panel as well.
Hope you guys enjoy the progress so far and stay tuned, there will be a lot more photos to come!
Cheers,
Alex
  #10
Old 27-04-17, 04:02 PM
ciobanulx's Avatar
Advanced Member
Hey guys,
Here's some quick pics of the motherboard going in. I know the Rampage V Extreme is a bit old now however it will match the theme perfectly
Also, huge shout out to Mwave Australia for sending over a 6850K for the build!
Time to get some water blocks on
Thanks for checking it out!
Cheers,
Alex
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
