Thread Tools Display Modes
  #1
Old 19-11-18, 02:58 PM
Anatomics Anatomics is offline
Newbie
Project Rose Quartz
Hello everybody
My new project is based on my previous build NATi Proto This project have inner part that slides from the back:
New project will be m-atx based and have motorized inner part that slide out from the back and outer part is 3D printed with 3mm glass windows.
Motor is basic metal gear servo that is made to turn 360 and controlled by arduino uno.
There will be custom loop for the cpu.
System specs are:
Cpu: I7-7740X
MB: Msi X299m-A Pro
GPU: Dont have it yet
Memory: XPG Spectrix D41 DDR4 32GB
SSD: 2 X XPG Gammix S11 480GB
PSU: Silverstone SX650-G SFX
Fans and controlbox is Silverstone
Big thanks to Silverstone and Msi for sponsoring this build.
  #2
Old 19-11-18, 03:10 PM
Newbie
Here is the inner part of the case with test components so you can see what the layout is:
And here is first design of the 3D printed outer case:
Top and front fangrills will be this design:
  #3
Old 19-11-18, 03:14 PM
WYP's Avatar
WYP WYP is offline
News Guru
Ooo, this looks like an interesting project. I look forward to seeing more.
__________________
_______________________________
Twitter - @WYP_PC
  #4
Old 19-11-18, 03:23 PM
Newbie
Thanks
First i did mod to the SX650-G PSU:
I cut the fangrill off and designed new one. I use MS 3D Builder for my designs. 3D print with Minifactory innovator for big parts and Ultimaker 2 Extented+ for little parts. Material is PLA
  #5
Old 20-11-18, 06:08 AM
Newbie
Next thing on my list is modify the servo to rotate 360 degrees. So lets get into it:
First step is remove top and bottom cover:
And take the gears out so i can take the pin off restrict the motor to spin 360:
  #6
Old 20-11-18, 06:09 AM
Newbie
One last thing to do is cut the potentiometer off and replace it with two resistors. Now servo thinks that it is on center position all the time and can rotate 360 degrees:
  #7
Old 20-11-18, 02:24 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Ooooh hello, we do like us some original modding.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #8
Old 21-11-18, 06:54 PM
Newbie
Thanks Trying to do my best.
Now servo is modded i make code for the arduino and feed it with two different pwm signal so it turs both ways.
I 3D printed little rail so i can test it and it works:
Then i designed bigger rails that fit on the aluminium inner case:
Had to cut little peace off the inner case so motor would fit:
Next step is mounting the aluminium m-atx stand to the frame and test the motor with components in the case.
  #9
Old 21-11-18, 11:06 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Sweet sweet electronics ! bonus points for the 3M safety tape as well, I use that hahaha.
__________________
"Those really high 20 series prices are just place holders"
  #10
Old 22-11-18, 12:45 AM
Bartacus Bartacus is offline
OC3D Elite
Cool stuff going on in here!
__________________
Guts: Ryzen 2700X / Asus CH7 Hero / 16GB FlareX 3200CL14 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: ADATA SX8200 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
