Thread Tools Display Modes
  #11
Old 31-07-18, 03:14 PM
Korreborg's Avatar
Korreborg Korreborg is offline
OC3D Crew
Started to install the new parts. The PCI slot is one spot lower compared to the ITX boards, so needed to find a new way to install the RES. Only managed to drill 3 holes. But it used to be mounted with zip ties
The new 400mm RAD with quick disconnects.
Filling the loop
__________________
[I9-7900X][Asus Strix X299-E][EVGA 1080TI FE][Corsair 16GB 3733MHz][Fractal Meshify C][Corsair AX860i]
[Samsung 970evo 500GB+1000GB of mixed SATA SDD's][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
  #12
Old 31-07-18, 03:21 PM
Korreborg's Avatar
OC3D Crew
The misses wasn't to impressed with the mess in the kitchen
Right one used, left one new. Or is it the other way around
Also a bit messy cables
Well finished and moved to the office
Made the fan profiles, so the internal fans only turn on under load. (But the have been running lots of days in this heat )
__________________
  #13
tinytomlogan's Avatar
The Guvnor
Be worth taking a bit of extra time on those LED strips on the rebuild
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #14
Old 31-07-18, 03:29 PM
Korreborg's Avatar
OC3D Crew
Well lots of pictures And i'm already in trouble. I have fallen for the PHANTEKS EVOLV X, so i'm thinking about an upgrade when the case comes out. We are moving to a house this november, where i'm getting a lot more space to play, so might get myself a playseat and a wheel
__________________
  #15
Old 31-07-18, 03:37 PM
Korreborg's Avatar
OC3D Crew
It has gotten better, but far form perfect. But i can't fit them hidden in this case
I will try to get some night pics without the reflections. They are not as apparent irl
__________________
  #16
Old 31-07-18, 03:38 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Looks quite nice!
I would however route the rgb strip the other way so they wouldn't shine in my face all the time, would drive me crazy.
  #17
Old 31-07-18, 04:04 PM
Korreborg's Avatar
OC3D Crew
Originally Posted by Dark NighT View Post
Looks quite nice!
There isn't enough room between the RADs and the glass. But the glass is tempered, so it is really not a big deal
__________________
  #18
Old 20-09-18, 09:06 AM
Korreborg's Avatar
OC3D Crew
Have pre-ordered the Evolv X, so a rebuild is coming.
Looking at some extra watercooling fittings, to make the loop draining easier, as the Evolv X have drain port. And also to prepare it for hard tubeing in the future.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
