Thread Tools Display Modes
  #41
Old 05-02-19, 04:53 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Love every time I come back to this build it's coming along so well and the effort really does show.
As for image sizes I can't say I've noticed, it's always loaded just fine for me either on 100Mb Fibre, 15Mb Broadband or 4G.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #42
Old 06-02-19, 09:18 PM
Pugsport Pugsport is offline
Advanced Member
thanks Wraith after today its now pretty much done apart from one channel to cut for the front two fan cables
today's progress
laying out for the cover plates on the second motherboard
had to take the back of the desk off and one of the handles off the router in order to get the router in to cut out for the motherboard 8 pin power
while i had the back off i also finished off the channels for the lower intake fans on both sides
right hand side
left hand side
then had to take the front piece off in order to get the router in there for the SSD cover plate
i did think for a fair while which side this SSD should be on, should it look the same as the other board or should it be a mirror image.
finally cut the channels on the underside of the motherboard so all the wires can be glued up out the way when finished
and thats its now apart from the wiring which can be done once painted so it wont have to come out again.
now its just paint prep and sealing the MDF up oh and i got some replacement LED strip in the post today to replace the strip in the lid i broke
  #43
Old 06-02-19, 09:30 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Is that a 4850x2?
Coming along nicely man!
__________________
"Those really high 20 series prices are just place holders"
  #44
Old 06-02-19, 10:07 PM
Advanced Member
Originally Posted by AlienALX View Post
Is that a 4850x2?
if you mean these then i think from memory they are 3850 or 3870 x2 cards but my memory is shocking
Thanks Alien, the real work starts now though or the work that i hope makes it come alive
  #45
Old 08-02-19, 07:19 PM
Advanced Member
well cleaned the shed up a it today and made a start on the paint prep
fibreglass around the cover plates on the right hand side
fibreglass sanded down
bodyfiller on to fill in any pin holes left in the fibreglass
fibreglass and filler in the front to try and hide the seam between the two different bits of wood
both SSD mounts filled
hoping to get the rest done over the weekend then it will be already ready for when the weather gets better
  #46
Old 08-02-19, 07:27 PM
AlienALX's Avatar
OC3D Elite
Ah yes of course ! they were identical to the 4850x2 ! same cooler everything.
Cool cards to have in your collection man. They were quite scarce.
__________________
  #47
Old 10-02-19, 04:49 PM
Advanced Member
yes which dose not help me remember which they are
yer think im going to make a stand for them and put them up on a shelf in the office when done, maybe along with some other parts
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
