Thread Tools Display Modes
  #21
Old 17-04-18, 09:25 PM
Bartacus Bartacus is offline
OC3D Elite
Cool pipes!
__________________
Guts: Ryzen 2700X / Asus CH7 Hero / 16GB FlareX 3200CL14 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: ADATA SX8200 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #22
Old 17-04-18, 10:06 PM
Dark NighT's Avatar
Dark NighT Dark NighT is online now
OC3D Elite
That looks really cool, the pipe design is great!
  #23
Old 17-04-18, 11:15 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Yup nice and original I like that !
__________________
"Those really high 20 series prices are just place holders"
  #24
Old 18-04-18, 11:35 AM
SeanAngelo's Avatar
SeanAngelo SeanAngelo is offline
Member
very nice work! can't wait to see the finished project!
__________________
i7 8700K @ 4.8Ghz | Corsair H100i V2 | Asus Strix Z370-F | G.Skill TridentZ RGB 16GB 3200Mhz | EVGA GTX 1080Ti FTW3 | ASUS ROG SWIFT PG279Q
Samsung 860 EVO 1TB - 850 EVO 250GB - Crucial MX300 M.2 525GB | Corsair RM650x | Fractal Design Define S | Corsair K70 MX Reds
Logitech G502 | Beyerdynamic DT770 250Ohm | Microlab FC330 2.1 | Schiit Magni 3
  #25
Old 26-04-18, 06:30 PM
SaaintJimmy SaaintJimmy is offline
Member
Update time! Finally got the MSI GamingX GTX 1080Ti I'll be using for this mod and went on with the modifications.
Did a thing with the top handles of the C700P... I kept seeing people polishing, brushing or painting them and I just didn't feel like doing the same thing, so I added some aluminum details!
Then went to back side of the case to figure a design out, came up with this freaky panel:
Then cut two openings on the side panel (f**k that was tough, that panel is a beast) as well as two pieces of mesh from the original front dustfilter to put them behind those strips.
Going back to the internals, having the graphics card mounted I could finalize the bottom shroud's pass-through holes, and I also started designing the cutouts to let the air flow (one of two rads is at the bottom)
  #26
Old 26-04-18, 06:44 PM
Dark NighT's Avatar
OC3D Elite
This is looking to be one of the best projects this year!
  #27
Old 10-05-18, 05:13 PM
Member
Ok I got a HUGE update for you guys, I must have forgotten to update the threads and ended up with 41 pics to share!
Today we'll see the last panels made, a custom lightbar and almost everything of the paintjob. Tomorrow I'm starting the final assembly!
Midplate vents opened
Drainport
Front cover for the PSU cables (because why place it the right way when you can do it reversed?)
Cover for the GOODRAM ram, which are red and don't fit so well.
Lightbar making
Fit and lighting test
Mods for the back panel
Now let's get everything ready for the painting phase. Honestly, my least favourite part but at the same time, the one that gives the most eye candy
Very close to the end. Please hold tight thank you for following!
  #28
Old 10-05-18, 08:39 PM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
OMG, just when I thought it couldn't get any better, you completely smashed it. Looks awesome.
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #29
Old 17-05-18, 02:21 PM
Member
And finally, the last update before the final pics. This one will follow the final assembly.
First, bottom radiator and psu
I made the power cord pass through the bottom dust filter
Mobo tray cover and top panel with tubes
Front view with reservoirs and clear panel installed
Midplate, more panels and pumps mounted
Soft tubes for the bottom section
And last but not least, hardline installation
Then filling, leak testing and air bleeding...
And it's alive!
I'd like to take the chance to invite to you to vote for my project in April's Case Modding Update: https://forums.bit-tech.net/index.ph...orsair.345005/
Thank you very much guys! Final pics coming in the next days!
  #30
Old 18-05-18, 12:26 AM
Dark NighT's Avatar
OC3D Elite
Absolutely Stunning!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
