Thread Tools Display Modes
  #1
Old 05-04-18, 09:29 AM
SaaintJimmy SaaintJimmy is offline
Member
CosmosX Project
Hello everyone, today I'm here to present a new project I'll be competing with in the Coolermaster Case Mod World Series 2018.
Some of you may think this will be like a space-theme given the similarity with the name SpaceX, Elon Musk's airspace company. That's not completely true, as this will be a green/grey/black mod and will only have little to no space references.
I chose this name because I personally am a fan of everything related to space, and I found "CosmosX" fitting with the mod because, if you look at the front of the C700P, it actually looks sort of X shaped. So I will start from there, shaping the entire mod using that concept, the X lines.
This is a mod that will go on display at the PC Frog store, so thanks to them for giving me the opportunity to make this project and for gathering two great sponsors together, Coolermaster and MSI.
Also thanks to Aquatuning and Alphacool which are always available to support me in my projects!
So let's start by tearing down almost the entire case. Since this is a really beautiful case by default, I found myself in a hard time trying to find an original layout, so the first days was pretty much entirely spent staring at it and trying some mounting for all the brackets.
This is what I came up with: standard orientation for the mb (even do I can choose to mirror this and do a reverse), which is centered to allow the mounting of two 360 rads on top and bottom. Pretty unique feature, the PSU will be mounted frontally, to allow the bottom rad to be mounted.
  #2
Old 05-04-18, 10:02 AM
Warchild Warchild is offline
OC3D Elite
I recently bought this case. Beautiful case to look at, great options and modding potential but very disappointed on the temperatures. It runs way to warm, even with watercooling.
Should be a good build log though. look forward to it.
  #3
Old 05-04-18, 10:46 AM
Member
Alphacool Eisbecher Helix Green in all their beauty!
Some cuts to make everything fit properly.
Acrylic panels at the back and front for a clear view of the internals.
Reservoirs and pumps mounted on the acrylic panels.
Now to the side cover and midplate.
  #4
Old 05-04-18, 11:52 AM
Avet's Avatar
Avet Avet is offline
OC3D Elite
It looks amazing.
  #5
Old 10-04-18, 03:13 PM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
Looks great. Subbed!
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #6
Old 10-04-18, 03:35 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
So far, sooo good. Great attention to detail on the panelling.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #7
Old 12-04-18, 05:43 PM
Member
Thank you for the nice initial feedback guys!
It's time for another big update. This time we'll take a look at the modding of the reservoirs, to make them nicer and sturdier, a bit of internal panelling and the customization of the front panel of the C700P.
Drilled and tapped some holes on the brackets for the reservoirs
Then made two panels for top and bottom and started to cut and tap these nice aluminum bars
Then cut openings for the ports
And here they are mounted
Let's get to the front panel! First I cut an opening on it
Designed and cut a nice touch for the opening
Then made this details using aluminum U profiles to give it some more character
As for the internal panelling, I had to cut some pieces of the mobo tray for when I route the cables and make the pass-through holes
And the last big internal panel is cut as well, now everything is nicely covered and ready for the next step, which is measuring holes for cables and pass-through fittings.
I also brainstormed a bit on the top panel because I had some difficulties trying to come up with an original design, and figured out I could some watercooling to help myself make it more unique...
So i cut some pieces of the mounting bracket of the rad first
(Can you even tell what I cut here? It's all about clean cuts hahaha)
And this is a teaser of what I'm going to do at the top
  #8
Old 12-04-18, 06:03 PM
sheroo's Avatar
OC3D Elite
Very nice detailing, keep those updates coming.
__________________
  #9
Old 12-04-18, 07:14 PM
WYP's Avatar
WYP WYP is offline
News Guru
Noice! I've been waiting to see somebody sink their teeth into the 700P. Can't wait to see the final product!
__________________
_______________________________
Twitter - @WYP_PC
  #10
Old 12-04-18, 07:45 PM
Dark NighT's Avatar
Dark NighT Dark NighT is online now
OC3D Elite
Omg this is going to look so incredible, following your progress on this!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
