Thread Tools Display Modes
  #21
Old 07-01-17, 07:52 PM
Bartacus Bartacus is offline
OC3D Elite
Get some acrylic and make your own back plate, a la JP Modified:
__________________
Guts: Ryzen 2700X / Asus CH7 Hero / 16GB FlareX 3200CL14 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: ADATA SX8200 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 1 240 rad / Singularity Computers reservoir / dual D5 pumps
  #22
Old 07-01-17, 08:10 PM
bloodycrashboy's Avatar
bloodycrashboy bloodycrashboy is offline
Newbie
Thanks Bartacus, that's something worth considering
__________________
  #23
Old 08-01-17, 09:56 AM
Ady6UK's Avatar
Ady6UK Ady6UK is offline
Member
Originally Posted by bloodycrashboy View Post
thanks for that Ady6UK, but €30 for the back plate + €40 for shipping is a bit out there mate
Yeah I know, when the shipping is more than the part it's a hard pill to swallow.
Bartacus's option looks viable though. Hope you find a solution dude.
__________________
Thermaltake View 31 case, i7 8700K, Asrock Z370 Taichi mobo, 32Gb (4x8Gb) G Skill DDR4 3200mhz ram, Samsung PM981 1Tb Nvme M.2 ssd with EK heatsink, WD Blue 3D NAND SATA M.2 2Tb with EK heatsink, 3 Tb Toshiba External HDD, EVGA GTX 1080Ti SC2 Black Edition gpu, Corsair HX750i Platinum PSU, fully watercooled.
  #24
Old 08-01-17, 06:54 PM
Newbie
Thanks mate, yeah, Bartacus's option is worth a good look, also Warchild suggested some red acrylic behind the writing I have cut out on the side panel which I like.
So just need to buy some
__________________
  #25
Old 09-01-17, 03:22 AM
Newbie
Originally Posted by Kleptobot View Post
Hey mate, couldn't help but notice the water jet cutter. Is that a techni waterjet machine by any chance?
Yeah mate, model - Techjet 3000
Made in 12/2004 and still cranking 😀
  #26
Old 09-01-17, 04:33 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Very nice job on the build mate, looking great
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=Asus ROG Swift=Corsair K95 RGB=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #27
Old 09-01-17, 08:36 AM
Newbie
Thanks Excalabur
I just need to do a little bit of finishing off and I'm done.
One thing I forgot to mention was the temperatures I now have.
The CPU is around 2 or 3 degrees cooler, that says alot for the Corsair H100 that I had installed previously, although I did have it with 4 fans in a push/pull configuration.
The GPU's are just so much cooler I have to pinch myself sometimes to make sure I'm not dreaming.
I didn't think it possible to be running at ambient, but that is what I have at idle!
Gaming which used to see 77° C on the hottest GPU is now running at mid to high 40's.
and of course, it's virtually silent
I am using Real Temp GT 3.70 software to give me the temperature, could it be lying to me?
MSI Afterburner gives me the same reading.
__________________
  #28
Old 09-01-17, 09:36 AM
OC3D Elite
You already answered your own question
__________________
DRAGON'S MIST
  #29
Old 09-01-17, 11:30 AM
Kleptobot's Avatar
Kleptobot Kleptobot is offline
Member
Haha thought i recognized it, i work for Technijet
__________________
delided 3570k (watercooled)
hd7970 (watercooled)
8GB Gskill XM
3*140 SR1 Rad
all stuffed in an FD arc midi
  #30
Old 10-01-17, 06:58 PM
Newbie
where you working there in 2004?
maybe you helped to build our one
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
