Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 28-04-14, 03:40 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
To speedstep or not to speedstep ?
So I noticed when I have speedstep on I get random little freezes because the clock speed has dropped for a second down quite low.
Now when I have have speedstep disabled this never happens and temps are literally 1-2'c higher at full clocks etc...
Is it safe to have it disabled or should I re-enable it ?
I know I should know this by now but I've never really used SS.
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #2
Old 28-04-14, 06:12 AM
Cru's Avatar
Cru Cru is offline
OC3D Elite
you generally disable it when overclocking
  #3
Old 28-04-14, 06:19 AM
Dicehunter's Avatar
Resident Newb
Do you always leave it disabled ?
I thought that might shorten the chips lifespan ?
__________________
  #4
Old 28-04-14, 08:16 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
Kind of the whole 'negative' side of overclocking dude.
Leave it off if you're OC'ing at all And if you OC you need to accept it will likely shorten the life of the chip
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #5
Old 28-04-14, 08:18 AM
Kei's Avatar
Kei Kei is offline
Advanced Member
Never had any issues with speedstep or the amd equivalent. (cool 'n' quiet) That's with all of my cpu's running overclocks. C states have caused me a few issues so i always turn them off. (huge jump in dpc latency vs off) Unparking the cores also helped to smooth things out a bit too on my 4820k, never tried it on my phenom but i think it would have improved things there too.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
  #6
Old 28-04-14, 10:34 AM
Josh Weston Josh Weston is offline
OC3D Elite
I've always turned mine off. Couldn't deal with the added issues.
  #7
Old 28-04-14, 10:59 AM
tinytomlogan's Avatar
The Guvnor
turn it off, if you want to save a polar bear plant a tree
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #8
Old 28-04-14, 12:45 PM
Dicehunter's Avatar
Resident Newb
I'd prefer to shoot the polar bear, Have a nice rug and chop down the tree to use as fire wood
__________________
  #9
Old 28-04-14, 01:20 PM
The Guvnor
deffo dont need speedstep then
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
