Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #41
Old 26-04-07, 08:44 PM
Rastalovich's Avatar
Rastalovich Rastalovich is offline
OC3D Elite
Be sure something is there to draw a load also, even if its just a fan.
__________________
  #42
Old 26-04-07, 08:51 PM
Joe Joe is offline
OC3D Elite
yea our server requires a extra PSu to drive the new HDDS (over a terabyte now !!!) problem is our jump start requires a permanent short to keep it active (even with a hddand fan hanging off it)
lesson :: some psus are just fussy mofos
__________________
I got 600 TFLOPS out a potato that i put in a Soc 775 mobo , proof? -- here is a picture of a piece of lint , surley that will suffice
OC3D ScreenSavers ::
|Available Here|
Got an Ipod? :: |Check This Out|
Isabelle Loves OC3D :: |THIS MUCH|
  #43
Old 26-04-07, 09:17 PM
Raging Raging is offline
OC3D Elite
its hooked upto the phase unit control.
it might have some kind of feature stopping it from starting.
Raging.
__________________
  #44
Old 26-04-07, 09:36 PM
JN JN is offline
OC3D Elite
Originally Posted by name='Joe'
yea our server requires a extra PSu to drive the new HDDS (over a terabyte now !!!) problem is our jump start requires a permanent short to keep it active (even with a psu and fan hanging off it)
Ye thats the same with all PSU's mate. If it's not hooked into a mobo, then you need to permanently short the green+black.
  #45
Old 27-04-07, 06:05 AM
Joe Joe is offline
OC3D Elite
thanks for the info .. i read a few guides that have suggested only jumpin it for a few seconds to catch the lot alas my experience and suspicion suggested otherwise .. thanks for the belief reinforcement man
__________________
|Available Here|
  #46
Old 09-05-07, 11:11 PM
DavidT DavidT is offline
Advanced Member
Bit of a bump here... but, how do I know which wire is which if the cables aren't color coded lol?
I have one of those Ultra FlexForce PSU's and all the cables are shiney UV blue.
  #47
Old 09-05-07, 11:25 PM
Advanced Member
http://ultraproducts.com/popupWin.ph...1851&img_num=5
Sorry, hit reply instead of edit.
  #48
Old 09-05-07, 11:35 PM
Allsorts Allsorts is offline
Advanced Member
If your ATX connector has the pins numbered on the side of the connector (probably in very small print) then you are laughing.
See figures 6 & 7. You need to short pin 14 (PS-ON) to any ground (GND) pin.
EDIT: I suppose you have a 50:50 chance of getting it right if the pins aren't numbered LOL. PS That is a really smart looking PSU you have!
  #49
Old 09-05-07, 11:46 PM
Advanced Member
Thanks, got it. They weren't numbered, but I just looked at the wher the cables were in the pictures, and put the Paper clip in the same holes, and it worked lol.
  #50
Old 09-05-07, 11:54 PM
Ham Ham is offline
OC3D Elite
Most. Useful. Trick. Ever.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
