Go Back   OC3D Forums > [OC3D] Hardware & Software > Networks & Security
Thread Tools Display Modes
  #1
Old 23-12-11, 05:24 AM
merrymustu merrymustu is offline
Member
Send a message via Yahoo to merrymustu
Hey guys, I have a query. Will installing a lan card in my current rig disable its onboard ethernet port?? Or can I use them both simultaneously as dual lan....My current onboard lan is realtek 10/100 Mbps and I was planning to buy a lan card with 1000 Mbps support. Also how do I find if my pci slot supports speeds upto 1000Mbps???
Cheers.
  #2
Old 23-12-11, 06:59 AM
BloomerzUK BloomerzUK is offline
OC3D Elite
Send a message via MSN to BloomerzUK
It won't disable your onboard LAN
__________________
  #3
Old 23-12-11, 10:15 AM
Member
Thanks mate ....Still unsure if my pci or pci-e 1x slot will support 1000 mbps though.....
  #4
Old 23-12-11, 11:00 AM
Toxteth O'Grady Toxteth O'Grady is offline
Advanced Member
Yes to both.
PCI 32-bit/66 MHz 2.133 Gbit/s
PCI Express 2.0 (x1 link) 4 Gbit/s
http://en.wikipedia.org/wiki/List_of...Computer_buses
__________________
Click on the red 604!! if you're curious
  #5
Old 23-12-11, 05:50 PM
Member
Thanks mate.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
